P500 500 Walker Evans Shocks for 520?
Broncbob
11
14
Are the lengths of the 520 shocks the same as the 500? I have Walkers on my 2017 P500, and the new P520 looks inviting as a upgrade. I’d like to swap the Walkers off my P500 if I decide to pull the trigger.
conk1234
canada
Yes the Walker evan shocks do fit fine just installed mine tonight,rears were about the same length and fronts were just a bit longer then stock shocks
Aerolite
Aerolite
114
499
Oxford Mills ON
Big improvement? Looking at doing this to our 520.
On the WE site it shows the rears have a remote reservoir only. Where did you mount that?
How long did it take to get yours, website says 8-12 weeks to ship. Thanks
conk1234
canada
Took 9 weeks from the day i first placed my order im also in canada so it took an additional week in customs for clearance it help take out the sharp joints over rocks I still have more testing to do, I'm also running 26 inch tires and I've changed out the final drive gearing to go faster think I top out over 80km/h with a clean airfilter and two adults in it
20210517 140752 20210517 140745 20210517 140723
stobiadas
stobiadas
115
462
K0E1X0
View attachment 272144 View attachment 272145 View attachment 272146
Hey there. Nice setup. I'm also in Canada and looking to do final gearing change on mine. Could you elaborate on the parts used and steps to change final gearing?
Thanks
conk1234
canada
P500 - A faster P5, it is possible.....gearing increase Its the exact same procedure as outlined here you still need to order a speedo drd and i set mine at -12.5% which is just about perfect, only big issue i found was my gears were back ordered and took nearly 4 months to arrive, the dealer even put them in under an emergency order for me as well, now only if my air filter would come in Id be styling
Shadesmn
Shadesmn
505
959
Ramsey, MN
If you look around Amazon you can find some very nice clamps for the reservoirs fairly cheap. They come in a few different mount styles
20180915 232554 20180915 232542
Chadwick1968
34
37
Angola la
I bought the 500 walker evens shocks for my 520. fit perfect and are amazing.
I just picked up the pioneer 520 yesterday! What did it run you for the four walker evans shocks and what type did you get.
