700 pioneer starting problem
W
williegoround
two times when temp. was 20 degrees or lower machine refused to start. changed plug at time but was no help. both times waited until temp. was above 32 degrees and machine started like normal. any ideas or suggestions?
41,933
Did it crank pretty slow? The stock battery is about the right size for a barbie jeep, and it has been suggested that a stronger battery helps immensely.
P
pappyo
593
2,380
1st Welcome from central upstate N.Y
Many good people & information on the Honda forum AND they LIKE PICTURES.
Check the battery 1st. ( as some have already stated while I was writing this)
Honda pioneer's are vary battery voltage sensitive. ( most in cold conditions use some sort of battery <> maintainer-charger.
Voltmeter reading <>below 12 volts<> can cause the problem you describe.
More information
Year mfg.
Miles
Battery age ( older the battery more likely the Problem )
How long did it set in the cold 20° temp ( cold temp can take up to 50% reserve power )
See your a member since Jan 2015
Do a search Many posts on this Subject.
107,286
E33B9292 5C0F 4C5E 8908 8FF37A3199F5
WINNER WINNER CHICKEN DINNER!! ☝️☝️🥳 8yrs first post!!
Knocked a few off that pedestal.
Welcome from the Putrid Swamp Run Michigan!
Need more Info bout your rig!
@pappyo about covered all that in detail!
Need pics Too!
Pics Or It Didnt Happen!
Been here 8yrs should
Know that anyway.
So assuming you have a 15’ cuz we have no info from you, we also assume u have the original battery. That baby is prob toast and It wont start in the middle of summer on the equator @8 yrs old. Again pure speculation cuz we have no info!
we will wait for that before we can go any further…..
