P700 Accessory switch plate/harness wiring
W
wataboy
72
107
SoGA
Howdy folks,
Got a couple of questions about the wiring on the accessory switch plate/wire harness. I’m trying to connect 5pin carling switches to the wiper and heater circuits of the Honda harness so I only need 2 wires hooked to the switches but which 2?Those circuits have multiple wires. See below. (I’ve already used the Honda accessory lights wires. Those were easy)
99811CAB 13CC 49E1 92CD AEBB73286BC0
Also which 2 pins on the wiper and heater fuse panel hookups would I use hook up the lights? See below. Hope this makes sense. Thanks.
2349B1BD FE8D 4FD1 B4AC A1832EAC05CB
W
wataboy
72
107
SoGA
Ok, I think I got some of this figured out. I hooked the red wire and yellow wire from the wiper switch connector to my carling switch and got 12v to the wiper molex connector in the distribution panel. From l-r on the molex the negative is #1 pin and positive is #3. See pic below.
Now the problem is the 7.5amp fuse blows when I hook the lights to it. The lights come on for a second then the fuse blows. I’m using rigid d-ss sku [HASHTAG]#262313[/HASHTAG] and according to rigid the amp rating is 5.14 and the wattage is 72. Any idea what could be causing this?
6490F850 CBDA 421D 81D1 67B796012898
63,845
Hi.
I'm sorry. I am not familiar with this switch panel.
I just looked at that light. is it 72w each or total?
72/12=6a.
That's not much extra room there for a 7.5a fuse.
I would jump up to a 10a and see what happens.
Put a meter on the leds direct to the battery and see what they pull.
W
wataboy
72
107
SoGA
Hi.
72/12=6a.
Thanks.
I put the meter(at 10A DC setting) in the light circuit & got an Overload message, so that tells me it's 144W or 12A's total. I'm gonna try a 15A fuse this evening & hope it holds. Fingers crossed.
W
wataboy
72
107
SoGA
Yup, 15A fuse worked. I tried to tie into the headlight wiring for the lower switch light positive but out of the 2 wires powered when the lights are on neither is powered all the time. One's hot with the low beams, the other with the high beams. So I just wired into ignition-on power. And thanks to Elkhunter for the cube mounting idea.
IMG 0755
IMG 0754
