Adam490's 1000R Live Valve Build and Shenanigans
57,047
Not going anywhere now….
404256C8 7768 4CC4 BEEE 1ED15F28508D
57,047
You got a link to that new plastic
Are you talking about my stitched together s*** or the actual replacement plastic 😂 ?? I can only help you with one of those...
RonAyers.com is what I have had the best luck with as far as OEM replacement plastics:
Left side lower (doesn't include the Honda emblem)
Left front upper fender
Honda emblem (silver/grey) - These are attached with little "speed nuts" that press on over plastic posts. I reused the ones from my old broken piece by cutting the posts with a pair of snips and popping them off with a screwdriver.
Left door hinge cover
I didn't replace this piece, but this would give you completely new driver side black lower plastics excluding the rear fender:
If you want the driver rear fender too...
57,047
New steering rack, new tie rods, new radius rod bushings, and all the plaz-tek put back together. Went out to the ATV park today and beat the old girl like a trailer park sugar daddy. Got the seal of approval from my co-pilot!:
N4i zrpa0AnJIa7ovmoMzNjgw703 h937 s noauthuser0
57,047
Haven’t done much to the Talon in a bit. Haven’t done a proper overland trip with the Talon yet so I wanted more Packout space in the passenger seat for our overland adventure for the M.O.M. Ride. Thought up all sorts of different things… Weld up aluminum frame, make extensions and mounts, plywood, blah blah blah
Drank a couple beers and came up with this:
2 hose clamps
1 plastic packout plate (have to punch the steel inserts out on the outer edges and drill the hole out to 1/2”)
Ratchet strap to keep the front of the plate from bouncing up and down. I picked up a paracord cam lock to try too. I can grab this and shake the entire buggy with no issue.
Hook the hooked ends so they grab the thick plastic floor panel drain holes. The clamps in the rear hold it really tight, just need the strap in the front to keep it from bouncing up and down. Not a lot of weight on the front even with a large packout full of junk.
Best part about this is you can pull it out and pop the seat back in in 5 minutes.
IMG 9350
IMG 9351
IMG 9354
IMG 9355
71461514188  484BF146 30C2 4134 A361 2F8897CD6BF2
IMG 9358
IMG 9359
71461591828  0AAB33D0 A610 48B7 8989 BE647668A4D9
TripleB
TripleB
11,935
101,315
Caryville, Tennessee
2 hose clamps
View attachment 400604View attachment 400605View attachment 400606View attachment 400607View attachment 400608View attachment 400609View attachment 400610View attachment 400611
That's some redneck hillbilly s*** right there.
ODAMO
ODAMO
1,177
3,206
First upgrade: Get rid of this stupid sticker!
Much better:
First thing I did on my 22 Pioneer was debadge all the stickers, most were crooked. Atleast you got Raised HONDA hood lettering and not just a cheap (and slightly off center) sticker.
I cannot think of any other vehicle with a Hood sticker instead of a hood ornament or emblem especially on their flagship utilty vehicle.
ODAMO
ODAMO
1,177
3,206
Yeah, I knew what I was getting into since the Pioneer bumper tubing is the same junk. It's definitely not a "bumper", more of a hood ornament.
Wow. as I continued reading I now realize the Pioneer had a magnificent hood ornament all along. LMAO😂
