Air filter replacement - Talon
Honda4lifeKS
Honda4lifeKS
15
104
Kansas
  1. Talon R LV
Going to do the 1080 filter add on but what replacements are best for the OE filter? Seems like UNI is widely recommended. Which UNI is it?
Reactions: Blownzuki and TxDoc
5,054
22,668
Yep, once you have the 1080 snorkel, the stock filter will last 'forever' and it's the best filter available anyway. I'm still using the original filter at 13,000 miles but I'm using a UNI prefilter because 1080 hadn't come out with his yet.
The filter at 6067 miles -
I THfbZb9 X2
highpocket74
highpocket74
1,842
5,877
Kinder, Louisiana
www.10-80dirtsports.com
If you're referring to a replacement for the OEM main air filter then Uni does not make one. There are very limited choices. Twin Air foam, K&N. Not sure if R2C still makes their air filter. I use and sell the All Balls OEM spec air filters. They work great.
I've been after Desert Craft to make a main air filter with their super great synthetic media but they aren't yet set up to make panel filters. But when they do I'll be ready! Their main filters they make for RZR and Can-am are the best out there.
906UP
906UP
13,125
122,571
da Yoop
Just to avoid any confusion @Honda4lifeKS , with the 10-80 ( @highpocket74 ) kit you'll still use your main air filter, the snorkel kit is a pre-filter......just in case that's what you're asking. As for the pre-filter, that's really your choice, some prefer the Desert Craft, I used the oiled Uni-Filter, it seems to perform better in my area
DRZRon1
DRZRon1
867
2,816
don’t screw with any other filter to replace the OEM - stick with OEM - there is nothing wrong with the stock air filter - it’s primo
Don’t try cleaning it , reverse air, etc…..
don’t buy the snake oil of HP gains, blah, blah, blah…….
the pre filters above all work outstanding if ya don’t want to spend money on air filters every few hundred miles
highpocket74
highpocket74
1,842
5,877
Kinder, Louisiana
Definitely do not remove the OEM air filter in the air box and only run an external filter!!
Reactions: Rayger143 and 906UP
