Aluma Trailer Mods
bumperm
bumperm
1,851
6,656
Gardnerville, NV
The storage box door on my Aluma UT12 does not have a stop. If the wind catches it or one is careless, it can hang down on the forward/outside of the box and this can bend the hinge mount forward. In turn, this can cause the lid to bind. A strip of wood held against the aluminum and judicious use of a hammer can straighten things out. I added a stop to prevent it from happening again.
The tie down on the lid is mounted with aluminum post screws, they're almost flush on the top. The side wall anchor point is an aluminum rivet nut mounted from the outside so it's flush. The screw is one of the many I removed from the color panels when doing the door storage mod. This retains the cable loop but also allows it to be slipped off if there's need to open the lid the whole way - though I don't see much need for that.
20220613 135335
20220613 141849
20220613 141843
