P700 Auxiliary Battery Install
G
gbuley
Huntsville TX
I am planning to add a winch and some LED's to my 2019 Pioneer 700 x4. I want to install a battery under the hood but the compartment under the hood appears to be nothing more than an unsupported, plastic box. There may be some structure below, that would support a battery, but I am wondering if there is an after market bracket that could be bolted to the frame, that would be capable of supporting a battery. I can fabricate the bracket if need be but this would certainly cost more and add hours to the project. Are there any recommendations?
Glock21user
Glock21user
" Nothing succeeds like excess "
1,820
9,056
Livingston county, Mi.
Several of us have done that very thing, search is your friend.
And there is no bracket aftermarket or factory that I am aware of.
osobad
osobad
6,618
58,535
Tampa Bay Florida
5 dollar winch mount from harbor freight bolted to frame to form a shelf Have since changed but worked great. Second picture is sheet metal use to lower it. Very easy to do
20210109 104733 20210216 160822
MTrockSlinger
20
76
Montana
No aftermarket brackets I know of but easy to fabricate your own. I used angle iron with holes so it gave me a place to zip tie wiring then added a 1/4” aluminum plate next to the battery box mount. The power steering bracket makes a great support shelf so it doesn’t need to be attached to the rear frame bar like the battery box brackets. I custom cut some heavy duty rubber work bench matting for the battery to sit on for cushioning and anti-slip surface. Project is still in progress so please don’t mind the messy wiring beside the battery. Still waiting on my insulated terminal strips to be delivered so I can mount them on the aluminum plate and clean up the wiring.
I also added my winch remote outlet up front on the grill for easier access and longer reach on the cable.
CB2C6D9C 11BA 4EDD 9839 99AEF8F61937
F011EC0A B5B0 40AC B8EB EA8451C45308
EFC35CC6 E337 454B B5D9 5E1B2A0F2C35
D895F244 ABD8 4E2C A7D0 76FF6E73B384
78B7E24F D9A8 4842 BF8E 4FC19554B906
9541FF59 8A56 416B 9BDB 193FD75B320C
BE3D6997 5E8C 4047 9BB6 B8B3DA18D110
FFD5CDFA CADE 4E46 BC39 D34CE7841676
88561F24 3D67 4452 85D2 41A3031758E9
