Axle ?
JM1000LE
10
36
Plymouth, Massachusetts
Need help with axles, I bought new Rhino 2.0 and they are not same as stock only took the front off but I got all four new ready to go. The stock axle has a gear or something on it that the new axle doesn’t have I think for EDC control. I’ve sent an email to Rockymoutain but haven’t heard back yet. The hub side is also different so I must have the wrong axles.
C8A41D9B 8A76 417C 90C5 791168580F40
11BB8257 1B83 45AF A99A BB10BCACEA91
NTCPrezJB
NTCPrezJB
President of #NTC
101,932
910,541
Canton, OH
LE? i4wd on your Pioneer
If so I don’t think the SuperATV axles will work. For a while there weren’t any aftermarket axles for the LE/i4wd units. Not sure if that has changed yet honestly
107,956
I’m going with bigger wheels and tires and just wanted to beef up axles. Also Front are clicking. I know I could just rebuild cv but I wanted to upgrade
How big of wheel and tire?
The stock Axels are pretty tuff.
Youll have a hard time rebuilding a clicking axel depending on what the click is? SATV talked about that sometime they were going look into an LE axel But it hasn't happened yet Unless he knows something we dont? Unfortunately, there isnt anyone that does. Your stuck with getting OEM.
JM1000LE
10
36
28X10-14 Aramid Terrabite 10 ply. On 14X7 wheels with 1” spacer in rear
ToddACimer
ToddACimer
Pioneer 1005-2
3,568
14,656
Oshkosh, Wi
Welp........I'm pretty sure they're going to be a whole new design. Frame tabs are different....and I had a dealer confirm that the arms are going to need to be updated.
We have a deposit, but no 2022 Pio 1k here yet.
Yes. I need to see another 2022 in person and take some measurements but my goal would be to wait for the 2022 arms to be out and get a set for my 2018. I can then use the new arms as a jig to add the 2 center tabs and have replaceable upper arms vs something 1 off.
