P500 Been away to long
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
Just checking after a long time away from site did nothing with E.R.V. last year but put a plow on it. Planning on doing some trail riding this year and I have parts coming to start an attempt at a 6x6 conversion for it.
NTCPrezJB
NTCPrezJB
President of #NTC
101,218
904,274
Canton, OH
6x6 ... that sounds cool as hell. I'll be watching the progress.
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
So I have a bunch of parts coming in so I can start piecing the rear end together with the major difference being it will have a front diff so I can eventually have a locker in it but also engage/disengage it as needed. It will be removable as well but I doubt I'd remove it once installed because it will have a huge cargo area in back. I have two possible routes to power it but I won't know which way until I get deeper into it.
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
Got 4 packages of used parts in and they are looking pretty good, 2 hubs, 2 spindles, 2 upper and 2 lower A-arms and a box of MISC. hardware just waiting on the diff and the other box of MISC hardware. If only I could find an inexpensive rear frame section but I haven't seen one yet and making it from scratch may end up being better for this project anyway. Those boxes of MISC hardware are like gold when it comes time to find the right bolt.
This project will take me a while but I hope to get started fabricating it soon I need most of the major parts here and I need my P500 here at this house before I can really get into it pretty much in parts gathering mode right now.
Since I'll be using a front P500 diff in the addon with rear A-arms/spindles I'll have to play around with the axles I'll use, I want rear wheels on it and at the same width as stock but I think the front diff is wider than the rear diff so there may be a bit of searching for the right combination.
The power transfer is still going to be a piece of work but I'm not even going to worry about it until I get something somewhat built.
Reactions: Isaiah
lee
lee
Village Idiot
2,342
13,150
Springfield Ohio
With the number of people buying a new frame only to use the front half to fix crash damage i would think there are rear frames avalible cheap.
Or where you doing 2 sets of fronts?
Fc9e629f99754ffb88414d9e63148b0a
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
pretty much going to duplicate the rear suspension except for the front diff that is going in there so I can engage/disengage the extra wheels as needed but the frame area in front of the rear axle/diff will need to be a little longer than the stock section so I can space the tires out the way I want them and make the addon frame section lock into the stock frame.
