P500 Best Tire size to gain clearance and still fit in truck
crushing
New Mexico
Thank you upstater . Is that in front or back or both ?
Also that is with your 1” spacers installed already correct? You really have me leaning towards the same set up , kenda bear claws HTR 26x9x12 front and 26x11x12 rear but without spacers . That sounds like it would put me about 51 1/2 “ and will still fit between truck wheel wells and get me about 1 1/2 to 2” more clearance. Only thing I want to look up is how much heavier the bear claws are vs the 2.0 bighorns
34,175
Where in New Mexico are you riding, southern flats or northern Rockies…..?
crushing
New Mexico
Hi , I live in Rio Rancho so rid a lot of sand on Mesa out here but do a lot of hunting in the mountains in both northern and southern New Mexico . So from in some areas a lot of sticky mud and in some areas very very rocky .
34,175
Nice! We’re outside Las Vegas. Ever want to ride the Santa Fe national forest out our back gate, give a shout! And welcome to the club….😎
BTW, I’ve had my P5 on its side twice, do be careful going up without going out…👍
crushing
New Mexico
Thank you Montecresto and if I get up that way I will let you know . Will be going to Pecos on camping trip in august and hoping to do something riding up there in national forest .
34,175
You’re welcome. I can ride right over to the Pecos out my back gate….👍
Reactions: crushing
Upstater
Upstater
22
61
Upstate NY
Both front and rear are ~53.25-53.5". Those measurements are with the 1" spacers on the stock wheels and 26" Kenda BC HTR's. I took the machine out to my off camber stuff yesterday and the increased width was helpful. I also took the ASB off so there is definitely more body roll (makes sense) but the added width never really made the extra sway feel to "puckering". I got a better feel of the terrain and definitely more heads up or warning of any tilt/lean. My wife described the feeling with the ASB off as the whole machine feeling a little softer/wallowing but smoother like the rear suspension in the back was replaced. I can't ask for a better takeaway than that. The extra articulation really helps in the rocky/rooty slow speed riding that we do. And in case you do end up with 1" spacers, the standard coverage mudbusters front fenders are the perfect width. I had to make my own rear extensions but for now they work well. I just need to figure out a bit of an extended flap out back. The first pic shows how the mudbuster lines up with my front set up and then how much overhang there is in the rear without any additional fender.
20210619 111737
20210611 143407
Reactions: Splorin and trigger
