BF Goodrich KO2 on a Talon?
Boundertom
163
572
AZ
@CID, I feel like you are reading my mind! :eek:
I was thinking that I would do a 2000 mile update. I am at about 1800+ right now. So by the time I head home at the end of next week, I should be there. So, keep your britches on for a few more days, OK?
The short version is: I am still VERY happy with these tires, and I would buy them again! Stay tuned for tread depths, photos, etc.
Boundertom
163
572
AZ
A few of you have expressed some interest in my experiences with these tires. Having accumulated 2,000 miles on them, I thought this would be a good time for an update.
Living in AZ, my Talon is street legal. I end up running a fair amount of miles on pavement, perhaps 30% or more. This is the primary reason that I chose the KO2s. I understand that there are quite a few DOT rated UTV tires available today. The difference is that the KO2s are designed for highway usage on vehicles weighing much more than a Talon. Simply put, I feel safer on these tires on the highway. The KO2s work well on the pavement. They are quiet enough that I cannot hear them over all of the other Talon noise. As I pointed out earlier, there is an increase in steering effort on pavement at low speeds. I think this is due to the KO2s putting a lot of rubber on the ground. As I mentioned earlier, I settled on running at 10 PSI, and found the ride to be very comparable to the stock tires.
I have also run these tires on all of the other terrain that I commonly ride, including rocky trails, sandy trails, gravel/dirt roads, and sandy washes. I am probably not super demanding of my tires, but these have not let me down yet. In the last 10 days I have had the "opportunity" to run on quite a bit of muddy roads. Now, I don't normally run in a lot of mud, and I don't like mud. The KO2s would clearly not be the first choice for anyone who does ride in mud. But, in my recent experience they did pretty well. Yes, they pack up pretty quickly- see the picture below.
I have a matching spare tire and wheel, and plan to do 5 tire rotations at approximately 1000 miles. Having done just one rotation so far, I have 3 tires with 2,000 miles, and 2 tires with 1,000 miles. The KO2s have 15/32" tread when new. The tires with 2,000 miles now measure very uniformly at 13/32". The tires with 1,000 miles measure at 14/32". I realize this is a pretty short test period, but that comes out to about 1/32" of tread wear per 1,000 miles. I will be watching this going forward, but it looks like I should be able to get at least 10,000 miles out of these. I am pretty sure I would do much better if I cut back on the pavement. I sure wish the Talon had a selectable locker in the rear! The tires show no irregular wear. These tires have a 50,000 mile warranty, but I don't think I will be able to collect on that!
As a bonus, I have had absolutely no air pressure loss, even though I am running on beadlock wheels. I have been riding ATVs for 40 years, and every one had loss of tire pressure. It is very nice not to have to worry about checking tires all of the time.
When I bought these tires, they were about $140 each, which I thought was a very good value. Like most everything in this country, prices have gone up significantly. They are now $166 at Discount Tire Direct.
I am planning a trip to Sand Hollow in early October. I expect to encounter some deep sand there. I don't expect my KO2s to be great sand tires, although we shall see. Warning- reminiscing coming! Many years ago i had a 1978 Jeep J-10 pickup with a 360 4 barrel and 4 speed. I had BFG All Terrains on that truck- 10.00x15, don't remember the diameter, probably 30". That was a decent sized tire in those days. I had a limited slip in the front and a TrueTrac in the rear. We used to go to the Silver Lake sand dunes on Lake Michigan. That truck did really well in the dunes on those tires. The tires on the Talon are ~.5" narrower, on a vehicle that weighs half as much. So it may not be too bad....... i don't expect them to perform like paddles! Anyway, I will try to give a quick update after that trip.
So, as I said very recently, I remain very happy with these tires. Based on my first 2,000 miles of experience, I would buy them again.
Pictures will show a tire loaded up with mud, and a tire as it looks now with 2,000 miles.
Let me know if you have any questions.
20210813 102432 20210821 152751
McCarthy
267
537
Canada
They will last a very long time, but the edges will round off and start to chunk in a couple thousand miles.
Boundertom
163
572
AZ
A quick update regarding riding in sand. I am in Hurricane, UT right now and have ridden some on the dunes at Sand Hollow SP. I am not a big sand guy, other than sandy washes, but I have been very happy with how the BFGs performed. I am sure they are not as good as a dedicated sand tire, but they have taken me everywhere I wanted to go. I started out at my normal pressure (10-10.5 PSI) and they did well enough that I never bothered to lower the pressure. I am happy!
BadMechanic
BadMechanic
64
314
53
New York
  2. Looking to buy
  3. 500
  4. 520
Not related to sxs but I have the KO2s on my F350. If they are anything like mine, youll make it through the worst terrain with no issues. Going on 5 years next month with 0 issues besides a nail in 1 tire.
Sent from my LG-SP200 using Tapatalk
Robobrainiac
Robobrainiac
2,460
8,569
I've been real happy with the Interco Sniper 920's so far. They are light, well mannered on the strreet, and DOT approved. The tread might be a little more aggressive than you are looking for.
How well have the sniper tires held up for you?
Reactions: ChadD and Smitty335
Robobrainiac
Robobrainiac
2,460
8,569
Put about 3k on then so far
Wearing good still smooth on pavement
grips everything
wanders a little in the deep washes but I guess what doesn't
no punctures in tread or sidewalls, they can take a beating
Thank you greatly!
