Big Red Maintenance Schedule
63,987
This is the Big Red MUV maintenance schedule for MUV700, all years.
[parsehtml]<table width="700" border="1" cellpadding="0" cellspacing="0" bordercolor="#000000">
<tr>
<td bordercolor="#000000"><span class="style1"></span><span class="style1"></span><span class="style1">Service the listed items at the indicated distance (or time)</span></td>
<td bordercolor="#000000">&nbsp;</td>
<td width="50" bordercolor="#000000"><span class="style1">Inital<br />
Maint-enance</span></td>
<td colspan="6" bordercolor="#000000"><div align="center"><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span>Regular Maintenance Interval</div></td>
</tr>
<tr>
<td rowspan="2" valign="top" bordercolor="#000000" ><div align="right">Frequency</div></td>
<td width="69" bordercolor="#000000"><span class="style1">x100 miles</span></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">1</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">6</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">12</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">18</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">24</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">30</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">36</span></div></td>
</tr>
<tr>
<td width="69" bordercolor="#000000"><span class="style1">x 100 km</span></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">1.5</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">10</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">20</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">40</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">50</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">60</span></div></td>
</tr>
<tr>
<td rowspan="2" valign="bottom" bordercolor="#000000" border="1">Items</td>
<td width="69" bordercolor="#000000"><span class="style1">Hours</span></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">100</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">200</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">300</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">400</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">500</span></div></td>
<td width="50" bordercolor="#000000"><div align="center"><span class="style1">600</span></div></td>
</tr>
<tr>
<td width="69" bordercolor="#000000"><span class="style1">Months</span></td>
<td colspan="6" bordercolor="#000000"><div align="center"><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span>12</div></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000"><span class="style1"></span><span class="style1">Check engine oil and coolant</span></td>
<td colspan="7" bordercolor="#000000"><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1">Check oil and coolant at every fuel stop</span></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000"><span class="style1">Check tires</span><span class="style1"></span></td>
<td colspan="7" bordercolor="#000000"><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1"></span><span class="style1">Check inflation and condtion once a month</span></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check brake fluid</td>
<td colspan="7" bordercolor="#000000">Check fluid level once a month</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Replace engine oiland oil filter</td>
<td bordercolor="#000000"><div align="center">x</div></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Inspect valve clearance</td>
<td colspan="6" bordercolor="#000000">Every 600 miles (1000 km) or 100 hours. </td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Clean spark arrester</td>
<td colspan="6" rowspan="5" bordercolor="#000000">Every 600 miles (1000 km) or 100 hours, which ever comes first.</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Clean air cleaner element</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check air cleaner housing drain tube</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check spark plub</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Inspect idle speed</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Checl fuel lines and connections</td>
<td bordercolor="#000000"><div align="center"></div></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check front and rear brakes</td>
<td bordercolor="#000000"> <div align="center"></div></td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check front and rear final gear oil</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Lubricate all hinges, latches, and pivots</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Inspect the following items:<br />
Suspension components<br />
Wheels<br />
Driveshaft boots<br />
Accelerator (throttle operation) and brake pedal<br />
Brake light switch<br />
Exhaust system<br />
Battery terminal condition</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Rotate tires</td>
<td colspan="6" bordercolor="#000000">Recommended every 1800 miles (3000 km)<br />
Depending on tread wear. </td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Check parking brake adjustment</td>
</tr>
<tr>
Tie-rod ends<br />
Steering gear box and boots<br />
Brake hoses and lines<br />
Vehicle underbody</td>
</tr>
<tr>
<td height="20" colspan="2" bordercolor="#000000">Replace the following items:<br />
Front and rear final gear oil<br />
Engine coolant<br />
Brake fluid</td>
<td colspan="6" bordercolor="#000000">Every 2 years (regardless of mileage)</td>
</tr>
</table>
* See owners manual for footnotes and exceptions.
[/parsehtml]
Let me know if you see a error of any type.
Similar threads
Replies
Views
430
Replies
Views
706
Replies
Views
1K
