P1000 Big tires rob power
A
AnthonyAce
16
27
Hurricane Utah
I put aftermarket rims and Terrabite 28/10/14's on all four corners and it took a lot out of the machine. I have looked through the forum for other discussions about this with no luck. Getting the tires spinning was much easier before and I used to hit 67mph fairly easy. I am lucky to get to 60 now on a downhill straight away. Did you guys see the same power loss? It's not gutless, but there was a definite dropoff.
A
AnthonyAce
16
27
Hurricane Utah
IF YOU USE A CALCULATOR FOR TIRE SIZE YOU WILL NOTICE YOUR SPEEDO SAYS 60MPH YOU WILL ACTUALLY BE GOING 62.2 IF YOU COMPARE 27X10X14 WITH A 28X10X14 TIRE . CHECK IT OUT Tire Size Calculator
Yeah, I've done the calculations, still not getting what it was. It's still fast, but like I said it is a noticeable difference.
Reactions: Lady01
NTCPrezJB
NTCPrezJB
President of #NTC
102,706
918,325
Canton, OH
Acceleration is naturally going to drop when the circumference of the tire is increased. "Taller" tires actually have a higher top speed as long as there is enough torque to turn them in the upper limits of the power band.
All things being equal...the shorter the tires (assuming the torque does not exceed available traction) the faster the acceleration will be to that gearing ratio's top end which will will be a lower MPH. Most people don't think about the tire size being part of the gear ratio but it most definitely is. The inverse of course being equally true...taller will accelerate slower but to a higher MPH.
Everything is a trade off.
A
AnthonyAce
16
27
Hurricane Utah
I totally understand all of that. It just surprised me how noticeable the difference was. I thought this machine had a little more. I thought my top speed would actually go up with the bigger tires, but I guess the torque isn't there to spin them. It did increase the weight of each tire/wheel combo by almost 15lbs/corner.
DTAGG
DTAGG
166
238
ST GEORGE UTAH/ACCORD LAKES SEVIER COUNTY UTAH
I was going to mention if weight was a factor ? enjoy
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Does anyone know what the weight of the OE aluminum (14") wheels and Bighorn tires are?
This topic is pretty important to those of us that like acceleration.
Personally, I've never driven the Pioneer with the OE tires. I had the shop spoon on the 27" MotoHammers off my trade before I picked it up. But it'd be nice to know how much weight I've added so far.. It might be the deciding factor on choosing a 27 or 28" wheel when the time comes..
Reactions: Lady01
175
493
Kansas
This is why I always research tire weights and make my final decision off of that. With all things being equal, I choose the lightest tire available. We're talking about a machine with 72hp and gaining 60lbs in rolling weight plus raising the final gear ratio. You'd notice a drop-off in power with a 350hp pickup with that much weight.
A
AnthonyAce
16
27
Hurricane Utah
Lesson learned. I had no idea it would make such a difference. I mean, I knew the effects it could have but thought the Pioneer was powerful enough to make it minimal. I will pay a lot more attention to that next time. On the bright side, I havent had a flat tire since going with the Terrabites. I think I had 4-5 plugs in every stock tire before I retired them. Every few rides I got a flat. These Terrabites hook up nice and show minimal wear after a few hundred miles.
A
AnthonyAce
16
27
Hurricane Utah
I dont have the deluxe edition. The stock base model tire/rim set-up weighed around 33-35lbs.
Reactions: Lady01
175
493
Kansas
A PowerCommander may be able to restore a little bit of the power but it'll never feel as peppy as it did with stock tires. At least you don't have to fear a flat anymore.
A
AnthonyAce
16
27
Hurricane Utah
Yeah, I've been looking into those a little bit. I'm a carburetor guy so I am lost when it comes to fuel trims/mapping. I'm waiting for a tune to come out specifically for those of us that have done intake and exhaust. I don't want to have to tinker with it at all. I do love the durability and traction of the Terrabites, but might look for a little lighter tire next time around.
Reactions: Lady01
mjn
mjn
1,409
5,206
It's funny you'd post this thread now.. I've been looking at tire/wheel combos for the last week or so. Your Terrabites are one of the lightest DOT 8 ply tires available (from the list I've looked at) I have a buddy that is running them on his Polaris 900 trail, and really likes them.
Here's what I found;
Tusk Terrabite 28/10R/14 =33lbs
STI Roctane XS 28/10R/14 = 33.8 lbs
EFX Motovator 28/9.5R/14 =41.8 lbs
EFX MotoClaw 28/10R/14 =36.2 lbs
My current EFX MotoHammers; Front 27/9R/14 =28.8 lbs, Rear 27/11R/14 = 36.3 lbs
Keep in mind, these weights are JUST the tire. If your 12" OE's were 33-35 lbs..... do the math.
I'm like you though, I will NOT deal with crappy 4 ply tires. I dealt with OE 4 ply stuff on my Brute Force, and sold that thing with plugs all over the dam things. I hate interrupting a ride with a flat. I won't do less than 6 ply ever again. I don't need big tall tires. The Pioneer has more ground clearance than the Viking did, and besides.. that's what skid plates are for. :)
A
AnthonyAce
16
27
Hurricane Utah
Don't get me wrong, I absolutely love the Terrabites. They are badass. Just didn't know they would steal my power. Yep no flats is a good trade-off.
Reactions: Lady01 and Jknac
Cmitchell
Cmitchell
12
35
Great Falls, MT
I just added new tusk terrabite 28x10-14s with tusk beadlocks wheels and love them! Just put 150 miles on this trip and couldn't be happier with them. Top speed affected? Maybe slightly but I also added two storage racks, spare tire, tool box, highlift jack and the whole family with a drop of maybe 7-10 mph top speed. Not bad in my opinion for hundreds of pounds added! So I only hit 57 instead of 65 jumping on the highway but for those very short times the tradeoff is no contest.
20180701 131932 1530728010103
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
Powercommander helps the bottom end quiet a bit. @joeymt33 just put 32" terra's with a PC and exhaust, no gear reduction and no problem around the TN/AL terrain. Rides like a Cadillac with big tires, elkas and later seat. Big tires do suck power out but on the trail it kinda of makes up for itself with the clearance and smoothness.
