Brand new Truck wont pull a trailer.
john790
330
1,017
Clinton ohio 44216
Brand new truck pulled trailer and 2 miles in trailer brakes disabled them selfs.My quess is they got tired.Never had this happen before no fix chevy has been working on it since June 2022.You cant fix s*** in your jammies working in the basement.
57,280
208,029
More info required? Trailer or truck?
NTCPrezJB
NTCPrezJB
President of #NTC
101,970
910,942
Canton, OH
I fix everybody’s screwups in my jammies working from the house. Granted I don’t work for Chevy.
Russ989
Russ989
22,601
146,866
I don’t care which of the big 3 it is, they all have issues.
john790
330
1,017
Clinton ohio 44216
I did ck the trailer over it seemed fine.Pulled trailer with different truck worked fine.Asked the dealer for a print out for the plug wiring on the truck could not produce.You cant even ck the truck with a test light all termnals are dead but the 12 volt hot.
Reactions: Plumber32
Jerryg
Jerryg
10,965
88,268
NEPA
Drive North until your hat floats, that will fix it.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
All pins in the seven pin trailer connector are supposed to be dead except the always hot 12v charge line when the truck is in a static condition.
Turn on parking lights to get trailer running lights, activate emergency flashers to get power to brake and turn signal lamps, and depress the brake pedal to get 12v at the trailer brake pin.
1674679279847
john790
330
1,017
Clinton ohio 44216
john790
330
1,017
Clinton ohio 44216
Thanks for the reply i really think i have a truck problem.Tried tails and turn with test light nothing i think the truck has to be pluged to the trailer for output to the plug i know that sounds crazy.Iam shocked no cut in stone for a 7 way round plug wiring.4 ways yes 7 way no.
