P700 buckle housing
jmanAZ
jmanAZ
57
50
tucson
Hi guys,
My 2020 700-4 has these net buckle clamps on each side of the front roll bar. Since I dont use the nets is ok to remove them permanently, so I can fit my led bracket on better? they're just held on with 2 torx srews. I would assume so as they dont appear to be there other than to serve as a buckle for the net.
IMG 20200710 125050
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,563
The Mud holes
Hi guys,
If you want, take them off. Shouldn’t mess anything up. 😉
Reactions: Backwoods
jmanAZ
jmanAZ
57
50
tucson
roger that. I noticed the older models of the 700 didn't have that brace, so prob ok. I'll just try not to roll it so I don't have to find out if those braces do anything. :)
NewHere2
NewHere2
Village Idiot In Training
35,805
304,292
High Plains of SD
The holes where the brackets mount are also used for the door latches if you install a Honda full cab. Shouldn't be a problem.
Similar threads
