P1000 Burning oil. Rings?
HBarlow
HBarlow
1,614
5,997
Daniels, WV
I have a suspicion on how it happened, about four years ago I had a 2 MPH flop, not on its side, but working on rolling. took a while for the rescue squad to catch up, it layed on it's side for probably 40 minutes before being up righted and pulled back on the trail. I think it hydro locked with oil, smoked like the devil when I started it.
Smitty,
I can't think of any way your engine could "hydrolock" in that circumstance. Oil in the crankcase has no path through an open intake or exhaust valve. But with the buggy laid on it's side, crankcase oil would flow up into the bottom of the cylinders and against the oil rings on each piston.
A small amount of engine oil would leak past the rings and into the combustion chamber. That oil is burned away when the engine is restarted hence the heavy blue smoke for a short while.
Loafing along at low speed on the trails, never using full or heavy throttle can cause carbon build up Mine is never run at high speed either but I usually accelerate moderately up to 45mph or so each time I take it out for a ride which is always on pavement.
208,135
Hey guys, I 've got stuck rings on #1 cylinder, had it leak tested, #2 cylinder is fine, bore scoped #1, no scored cylinder wall, exhaust doesn't smoke at all. You can smell it while under compression braking, no oder otherwise. 4,440 miles. I'm going to try a ole trick my Grand Paw used on his old bailer every Summer. I need to flood #1 cylinder with Marvell Mystery Oil by pouring oil down the air intake to #1 cylinder and let sit for a week, Grand Pa unstuck many rings doing this.
I don't know which is the #1 cylinder, front or back?
john790
330
1,017
Clinton ohio 44216
Hey guys, I 've got stuck rings on #1 cylinder, had it leak tested, #2 cylinder is fine, bore scoped #1, no scored cylinder wall, exhaust doesn't smoke at all. You can smell it while under compression braking, no oder otherwise. 4,440 miles. I'm going to try a ole trick my Grand Paw used on his old bailer every Summer. I need to flood #1 cylinder with Marvell Mystery Oil by pouring down the air intake to #1 cylinder and let sit for a week, Grand Pa unstuck many rings doing this.
Well i will be the bad guy what oil do you use.
DRZRon1
DRZRon1
922
3,053
PA
#1 is the one that you had leak tested and bore scoped
208,135
I'd just pull the piston and put rings in it. Maybe 4-5 hour job at the most.
Can you re ring without splitting cases? I'd like to try to free up with oil on top of the piston first. The quotes came in at $2,500-$3,800 with cases, which I can't afford right now. Which cylinder is # !?
Reactions: ChadD and Buggyman
Buggyman
Buggyman
36,332
308,520
ne. ohio
I don't want to pull both plugs on restart, figure treat #1 cylinder and let it blubber for a little until it cleans out in a week.
Mystery oil is good stuff my grandfather used it in both the oil and the gas never had a problem. when the water company came out to turn off the main for me the valve 48" underground and 60 years old was froze, pored some mystery oil on it let it sit while we drank a bottle of water and it turned like a brand new one.
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Isn't the air intake is common to both cylinders?
I don't understand how you can pour Marvel Mystery Oil into the air intake and only fill #1 cylinder.
How did you determine piston tings on #1 cylinder are stuck?
208,135
Read above, all the info is there.
Jerryg
Jerryg
11,140
89,650
NEPA
We used PB Blaster to free seized engines.
If you think it really is stuck rings, remove the spark plug and spray some PB Blaster into the cylinder and let it sit for 24 hours.
208,135
We use PB Blaster at work all the time, works great but it's not a lubricant and I fear damage on restart. Marvel Mystery Oil is a lubricant. No one can tell me which is #1 cylinder, so I'll wait until Monday and call the UTV shop and find out, then treat #1 for a week. Another reason to pour it down the intake tube is you want to smother out #1 so you know you've got enough oil in the cylinder.
