Can’t read gauges
Teammontana
Teammontana
24
44
Arkansas
is there a solution to the gauges being unreadable once there is a little dust on them? 2018 100/5.
JenElio
JenElio
65,015
608,634
Loxahatchee, florida
200w 1
Teammontana
Teammontana
24
44
Arkansas
Thanks for the input. Never knowing how fast you’re going, how much fuel, not being able to see potential engine problems is an issue. Wiping the dash off with a glove you might see the speed for a few minutes but you have to stop to get it cleaned completely. Then it only works for a few miles given the excessive dust inside the cab. Leaving the lights on all the time sorta helps. I think the solution would be to relocate them on top of the dash with a different background color and larger display. Even a white background on the stock unit would make a big difference. Sounds like a small problem, but would you drive your car if you couldn’t see the dash?
JenElio
JenElio
65,015
608,634
Look, I'm not saying it gets dusty but........nothing a quick wipe can't fix. Maybe try a rear screen to help keep the dust down. Have you tried a quickshield from @trigger? I hear it eliminates any and all dust 😉
Also, if none of the above work..........they say jeep makes a good 4X4......🤷
DRZRon1
DRZRon1
864
2,804
PA
a jeep is an outstanding and great solution - these are sold and advertised as off road machines and the dust\cold\heat\water are to be fully expected.....
Honda delivered a sub par dash imo - I just wanted to see volts\temp, the stupid fans on the display tell me s***\wanted a real number. oil pressure would be great but by not so critical - if oil pressure is lost - usually screwed at that point anyway. ill do RPM\tach at some point
since red is the fastest - typically always got 50+ - lol
IMG 7721
IMG 6085
HondaTech
View attachment 375607View attachment 375608
You'll know when you lose oil pressure, the engine will shut off. The PCM only knows when the trans looses pressure, so it shuts the engine down.
