P1000 Cheap tire that won't tear up my yard?
JenElio
JenElio
65,078
609,039
Loxahatchee, florida
Buying a set of blackwater evolutions for duck hunting, but almost certain they'll chew my yard to pieces. Looking for something cheap I can use when it's at home. Thanks!!!
If you run it in turf and slow down a bit it should be ok......or you can always buy some street tires and have a separate set of wheels and tires for "yard work"???
Robobrainiac
Robobrainiac
2,464
8,600
Is your machine all stock?
Robobrainiac
Robobrainiac
2,464
8,600
Highlifter still has their sale going on. You could get some 15s and then 235 75 15 all terrains
Scoop
Scoop
4,241
15,885
  3. Talon R LV
+1 :cool:
Talons don't haz turf mode - 😢
Just realized this the other day ... a couple of days after bringing one home. LOL.
1690304421234
Mopower58
Mopower58
CST is the Best!
70,985
650,427
Crystal Springs,Ms.
I thought you had a P1K-5. It comes with turf mode,aka 1 tire in the rear only pulls.
Scoop
Scoop
4,241
15,885
  3. Talon R LV
I bet if you check Craigslist or Facebook marketplace you’ll find some steel rimed factory take offs.
Before I got my aftermarket tires & wheels, I wanted to pick up a steel front to use as a spare when running my OEM tires on the different sized Deluxe OEM aluminum wheels.
I snagged a full set of steelies from a base model P1K5 for $50.
No, they are not for sale, @DawgU ... :)
Vikes79
Vikes79
SKOL!
10,993
106,728
South Dakota
  2. Talon X4 LV
I went the other way, had the base model with the steel rims and the black stones. I bought some deluxe take offs with the bh2.0’s. I leave the BH on for most of the summer and winter.
When I spray pastures, I put the steel’s back on as I never really know what I’ll drive over by accident (old wire, metal pieces, rocks, stumps, etc) and the extra flotation is nice when you got 700lbs of water sloshing around when your going 6-8 mph across a mostly unknown pasture.
The base model tires are adequate for what they are and really aren’t hard on the ground either.
Robobrainiac
Robobrainiac
2,464
8,600
Today yes, but Texas Tough Customs 3” on order
I have the c-fab 3" arms and I can clear 30x9.50r15 Achilles Desert Hawk MT. I use them specifically at home and so far they do well in the yard. Wet grass on full turns will chew it but I would assume any tire that is not turf specific would do that.
207,989
Man that's a lot of weight, I know you can't put a 700 gallon tank in the back of your 1000-5, what kind trailer do you use?
  • Haha
Reactions: Vikes79 and JenElio
