BRed Codes
T
Tickhound93
Iowa
Hey guys, new user. Short intro then my question, I own a small power sports repair shop in northeast Iowa, just opened up this year. I'm all by myself in the shop and not dealer affiliated.
My question, I have a big red 700 in here, 2012. Customer said it died and wouldn't start. After a bit it started. Couple days later, it died and would not start again. Said there was a backfire, it shut off and would not restart. I checked it out and found the magnets all wadded up in the aramature. I want to send it into self diagnostic mode to retrieve codes to see what caused the backfire/ dying issue. Anyone know the sequence or if it can be done without a scanner? Dying issue may or may not be related to balled up starter, just looking for any codes that may give me some insight. Thanks all
64,090
Welcome @Tickhound93,
Starters are known on the BR's to come apart. That will be your starting issue.
Is it showing codes? Normally it will flash if there is something. I would have to dig into it myself to give any more info. But check this post out - Big Red Service Manual 2009-2012. Divided downloads.
It requires a "special" tool. Which is just a wire jumper. You can DIY your own out of wire once you figure out which wires it is.
Other then that, u know the drill. gas, spark, filter, oil are not bad.
Oh.. have been few reports of fuel pumps but nothing big.
T
Tickhound93
Iowa
It is not showing codes. But if you could find info on the jumper wire that would be great. I have a special instrument board I will hook up when I get it started, battery volt meter, fuel pressure and oil pressure gauge, timing light and 02 sensor. I will use that to diagnose the stall. Also worth mentioning I just did the top end on it 2 weeks ago
T
Tickhound93
Iowa
Download chapters 4-7 from the link above and look at page 6-12.
Link does not work. Says address is invalid. If I can get a definitive answer on this I will share it so people know.
T
Tickhound93
Iowa
Try this link - Dropbox - Big Red chapter 4-7b.pdf
Sorry, not many big red owners around anymore to help.
But without the MIL blinking I dont think you have any codes to pull.
You sir, have done a huge favor for me. I owe you in 12 ounce currency. Thank you so much. If I can help you out in any way, let me know. I do a lot of atvs, bikes and Stihl chainsaws. Need anything give me a holler
Reactions: Hondasxs
