CP’s Talon Rebuild
320,603
Great day at the dunes today. Look at the roost coming off the tires from my daughter drag racing. She crossed the line first. Few pics of her jumping too😍
JAT still going and kicking plenty of ass still. “Slightly” more haggard and more mileage then anything else out there
IMG 0836
IMG 0835
IMG 0817
IMG 0820
IMG 0797
IMG 0793
NTCPrezJB
NTCPrezJB
President of #NTC
101,773
909,084
Canton, OH
NorthernJoe
NorthernJoe
332
1,276
Northern Ontario
View attachment 421721View attachment 421722View attachment 421723View attachment 421724View attachment 421725 View attachment 421726
Looks like a great time! You got some awesome shots
320,603
Few pics from the weekend. Daughter and I hit the trails. Got into s*** we really shouldn’t have being alone in single machine but the Talon got us back out yet again.
IMG 0918
IMG 0921
IMG 0935
IMG 0931
IMG 0937
IMG 0932
IMG 0926
320,603
Hey, U Krazy Sh!t - R U still running without a low range? 😲
Ya. Been over 4k miles like that. Gotta hit things a little faster then I’d like sometimes and stay in manual but it’s doing it
Watched a bunch of belt issues behind me though🤣
Neohio
Neohio
Beast of the East
13,442
66,067
Painesville Ohio
Pulling the subtrans isn't fun. I just got one out of the Talon in my shop. After I figured out that neither prop shaft had to be removed, I slide the front diff forward and the subtrans kinda fell out.
320,603
I hope it’s not too bad. Hopefully be easier I’ll have a lot of stuff out of the way at same time
Neohio
Neohio
Beast of the East
13,442
66,067
Painesville Ohio
Pull the subtrans before you pull front prop shaft. The front bracket was/is ignorant to get the DS bolt out of. But remove some bolts a,d push pins from the area and you can slide the floor up a bit.
I used a ratchet strap around the front diff to pull it forward, once it was forward, I slide the sub trans forward on the 2 m8 studs. disconnected rear shaft, (made sure it wasn't stuck) then slid it back on the studs, removed studs, push subtrans forward to disconnect rear shaft, then drop out the bottom, slide it back off front shaft. That part took me forever to realize I could do it that way. Every video I watched, guys made it sound like front shaft had to be removed from subtrans before dropping it. That wasn't the case for me.
320,603
That’s great info! Man I appreciate it, I’m about 3 weekends of riding till I can get on it.
Neohio
Neohio
Beast of the East
13,442
66,067
Painesville Ohio
CP, If you can find some M8 (8x1.25) jam nuts, or make your own, it will make removing the 2 long studs easier. I had barely enough thread engagement on the 2nd nut to lock together and remove the stud. I grabbed a few jam nuts from work and will use that to put back together.
320,603
Ya that’s no problem. Thanks Neohio!
