Multi Cube lights
Trademark
Trademark
66
152
Arkansas
So I got my SuperATV windshield put on a couple of weeks ago and I'm looking to add some LED cubes to the front. For anyone that has a flip up windshield, is there a certain mount that works with the limited space between the cage and the windshield? Or are you guys mounting the lights some other way?
Pioneer
Reactions: Russ989
Russ989
Russ989
22,588
146,743
You may have to be creative or more selective, I have the Honda windshield and have thought about doing the same thing.
Reactions: Mudwing
Russ989
Russ989
22,588
146,743
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
id never really faded it just peeled \flaked off
Reactions: Russ989
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
That’s crazy!
yeah i think they are just dipped. if id known that when i first bought it i would of put a thick coat of some clear coat on it.
Reactions: Russ989
aauman88
aauman88
1,091
2,846
I think it was just the early version Camo’s that did that, my buddies peeled off with pressure washer
Russ989
Russ989
22,588
146,743
That would have helped quite a bit, I always used the krylon clear coat.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
If just cubes you are looking to mount you can use the front bolt holes that are just in front of the windshield. I pulled the bolt and went to Lowe’s were I bought a little longer bolt to put in.. a tip for you is to pick up a fender washer and a rubber washer - put the rubber washer against the plastic and then the fender washer on top of .. I went ahead and used another rubber washer on top in between the fender washer and the bracket.
F0598896 1DB7 48F6 B4E7 CC3CB0E7B0AE 81310B5B BCE4 47A4 94D7 CCBBAD1DD328 6B4E3E56 2F30 4E64 8AA6 F59378396DDF
L
LCK_Boater
39
39
Lebanon, OH
Reactions: Russ989
aauman88
aauman88
1,091
2,846
Mine is a 54” straight
Trademark
Trademark
66
152
Arkansas
View attachment 154007 View attachment 154008 View attachment 154009
Unfortunately the 700s don’t have that same bolt hole. But I appreciate the input!
4C37B914 420A 4268 834D 4E58A3F21EEA
Reactions: Ragnar406
Trademark
Trademark
66
152
Arkansas
View attachment 154170Look at Magnum Outdoors A pillar mount
These are actually exactly what I was looking for but it says they only make them for the 1000. Anyone know if the two bolt holes line up the same on the 1000 as the 700? I can't imagine they would be different but I've been wrong before.
