After putting a few miles on my R, I could see it wasn't going to take more than a few hundred miles for the rocks and gravel spray to remove all the powder coating from the bottom of the trailing arms and from the shock mount area. So I ordered the Honda trailing arm protectors. Nice enough product, but not enough to do the entire job of protecting the arm, the lower shock mount, and that ball joint boot way at the back end of the T.A.
So I started designing my own. Finished one design and built a set of parts for the drivers side, but wasn't happy with the complexity and construction difficulty of that first design.
So a second, completely different concept was attempted. This newest concept is a winner, and continues to satisfy all requirements. It combines a clamp-on channel type arm protector, with a blast flap. Photos of drivers side.
ATTACH]127288[/ATTACH] ATTACH]127289[/ATTACH]
As I prototyped this first one, I templated everything, so the other side should be easy enough to build tomorrow.
There are two stainless steel plate parts which serve to clamp the HDPE flap part to the channel part. Only HDPE plastic touches the Honda trailing arm, the stainless plate parts do not touch the trailing arm, so no paint damage. No holes are drilled in the Honda, everything clamps in place. The blast flap is replaceable in case it ever does get bent or torn.
I'll fabricate the passenger side setup tomorrow. Looks like a winner to me.
![20190504 105150 20190504 105150](https://hondasxs.com/data/attachments/126/126494-051978b27572584fe50b48292121cd1f.jpg)
![20190504 105136 20190504 105136](https://hondasxs.com/data/attachments/126/126493-3df5e1c7e972952d4e167883fe29fc6b.jpg)
