P1000 Dash Light for Factory Switches
czajkaej
czajkaej
Ridgecrest, CA
I installed a simple LED light above the middle factory switch, so I could find the darn things in the dark. It’s similar to what modern cars do, single LED shining from above to dimly light an area. This will make it easier to find the switches on night rides.
6AF5EF29 0CA1 4732 9AAD E6B59225E031
55E92C29 E523 40A7 891F 94E53E449B54
Darby
82
145
Salem, Oregon
Did You tie into your headlights so this light only comes on when You need light... or is it on all the time? I'm trying to figure out how to do this, with the light(s) tied to turning on headlights......?
Reactions: NTCPrezJB
bumperm
bumperm
1,848
6,641
Gardnerville, NV
Indirect panel lighting is often used in aircraft - well, at least for older instruments that don't have internal lighting. They are referred to as panel lights ot post lights. Here's an example that provides indirect lighting and should work well:
panel light
Reactions: Darby
Jankyeye
Jankyeye
521
2,255
Tampa, Fl.
I used rock lights, switch and dimmer. One in the front center and two at the b pilers.
IMG 6060 68498156916  A529B98F EA51 4CAE 96D3 6AB871F33617 IMG 5517
Darby
82
145
Salem, Oregon
I went this route.... the red directional light up high on the dash is a "key on" light so can see the OEM light switch and tell what gear / drive i'm in.. (red, easier on eyes, and put a little cap on the end to keep from direct light to driver), and 2nd picture shows when headlights are on - the red LED strip lights up to see all the other switches - as well as the glovebox light.
IMG 6869 IMG 6870
Reactions: Buckaroo41
