Dear Honda
Backwoods
Backwoods
32,192
330,572
Douglasville ga
HOPE NOT!!!
The dealer had told me the front stayed engaged but did not pull unless in 4WD ????
Anyone else notice the front differential feels like it’s in 4WD when turning on pavement???
I have no problem and have never noticed anything like that.
41,749
HOPE NOT!!!
The four-wheel drive is engaged and disengaged with a sliding collar in the front diff. There is no "semi". It's kind of like being pregnant...Either you are or you aren't. The front shaft will always turn, but it will not be transmitting power through the diff in any form in 2wd. It's possible there's a cable misadjusted. The easiest way to check this is to Jack the front end up, put it in 2-wheel drive, and see if you can spin the front wheels. The open nature of the front diff means you have to spid both at the same time. In 2 wheel drive, there should be nothing more than the normal amount of drag from brakes, seals, etc as far as resistance to turning the wheels.
The 700 pioneer is one of the few vehicles I've ever owned where it was actually difficult to tell if it was in 4-wheel drive from the steering, assuming I had the tire pressures all the same. Diff lock, obviously, is another matter, but in two wheel drive, the only scrubbing you should experience from the rear.
P
Pilot2016
118
173
Rockhill Sc
Thanks DG
Are you saying it could be the resistance from the REAR WHEELS that I feel when turning sharp in 2WD on pavement ????
(2018 P700-4Delux)
If so....Does that mean that the rear 2 wheels are the one that stay connected 2WD or 4WD ???
I really have no clue but I will jack it up and do what you suggested tomorrow 👍👍
THX AGAIN
156,149
Does the handle KNOB twist off on the P700 so you can slip the rubber down the shaft OR do you have to access the handle and remove it from behind the dash??????
thx
I made that one for the 500 and it'll slip over the knob. No idea what a 700 shift lever looks like. Heat, twist, pull and pry, it'll come off.
Fist 1
P
Pilot2016
118
173
Rockhill Sc
After looking at it, you’re right.... the slit will be plenty big on both 3 position levers on a 700.
THANKS for a simple solution as I start heat/sound seat protection tomorrow!!!!
Gives me another COVID Project 👍👍😅
P
Pilot2016
118
173
Rockhill Sc
Thanks DG
(2018 P700-4Delux)
THX AGAIN
DG
You were right.👍👍👍 The front wheels turn independently. It must be the rears binding on pavement. (Ive only had this machine 5 hours of driving—-1st SxS...Had a Rincon 15 years.).
The 700 must be like the 1000 minus the turf mode??? Found this on the forum:
THX
03A45DC8 92E0 4474 B3FB 594F692E5D7B
41,749
DG
THX
Yes. With the exception of turf mode being "one wheel drive". What turf mode does is allow the rear diff to operate as an open diff, meaning torque can be biased between the two wheels as needed by different wheel speed demands. The only vehicles with "1 wheel drive" are bikes, motorcycles, and powerwheels toys.
56,719
Yep, only time you get "1 wheel drive" in Turf is if you get stuck and diff out to whichever side spins easier.
P
Pilot2016
118
173
Rockhill Sc
Thx👍👍👍
Reactions: Biteme
Mike Martsolf
94
187
elko, Nevada
Well Honda, my wife and I had hopes for the new 520! Well you managed to keep the same "spartan" 500 and added a dump bed...I had high hopes for something a little more upscale, to enhance the reliability and usefulness of the P5. Perhaps a DELUX model w/power steering and nice wheels, a softer more aesthetic looking seat. Well we have retired our trusty P5 to our mountain cabin (maybe used 2/3 times a year) for a full size utv (sorry it is not a Honda), but thanks for the dependability and reliability of the P5
russknight
russknight
1,916
7,542
Perry Florida
Dear Honda, please hire some Polaris engineers to show you how to build a comfortable, smooth riding, well fitted machine. In particular, hire the ones that designed the Polaris Northstar.
Thanks.
