P1000m5 different snorkel types
L
LarryAmboy
894
1,979
Castalian Springs, Tennessee
Radiator. I went to Napa with the diameter I needed and they had the ability to look up radiator hoses by inlet and outlet diameter. At that point I just chose a shape that I thought would work and ordered it. I got lucky and when I picked it up knew it was perfect.
Sent from my SM-G920V using Tapatalk
What filter did you use and how is the filter attached?
Macory
5
michigan
I just took the stock rough particulate filter and stuffed it into the end of the hose. It's stout enough that it stays right in place. The end of the spring inside the hose holds it from being sucked in a little too. If you haven't had yours apart yet it's the little white square thing in my pic.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
really thinking about going that route. Messing with the highlighter kit i haven't found a way i like it yet.
N
Nipper
84
136
Oklahoma
I've dove into a creek (literally) from the bank and nail the rev limiter in 6th with ease (what airflow restriction?) Back to stock in few minutes without buying a single part. And best of all, no sign of water intrusion in airbox whatsoever. Still very happy with decision to install behind the seat type. Only downside was the price but not bad compared to the HL. And I'd like to see someone snag mine on a low lying limb lol.
How is the noise with your behind the seat snorkle?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Through the hood snorkel.. apparently 3" PVC isn't 3" OD.
Did you use 3" hole saw or 3 1/4?
How tall and what pipe? AEM 36" off amazon? was hoping to be cheap with pvc
208,135
Mdtfc
Mdtfc
50
90
maryland
What inside diameter hose do I need to fit the intake hole? I don't have my pioneer here to measure right now.
Shields
Shields
Louisiana
Has anyone toyed around with redo the tubing around the motor area? Looks just be some flex boots and stuff. It seems most try to reroute from under the hood, instead of tapping into the pipe that runs from the hood. I haven't really checked the feasibility of this myself. I noticed it yesterday when ripping out the seats and stuff to fabricate a bilge fan bracket.
I can out of air box into 3" tee then reduced to 2 - 1.5" flex pipes that come up each side of air box. Use 2" x 3" female coupler coming out of air box. Used dremel to grind inside out to 2.5" so no loss in air flow. Used warrior risers for a finished look. Pics are from mock up. I did add a 3" rubber connection between air box and tee to make easier to remove for maintenance. A little trimming to air box cover and front panel of bed to allow snorkel to clear and every thing works good.
20170725 190232 20170725 190300 20170725 190210
Shields
Shields
Louisiana
View attachment 51524 View attachment 51525 View attachment 51526
Here is a little better pic of snorkel.
20170729 085948
Smaine
10
Iowa
This looks like maybe the best option yet. What did you need to grind out with the dremel? What type of flex pipe? Thanks in advance for any info you can share.
Shields
Shields
Louisiana
I used a 2" x 3" female coupler to come out of factory flex tube on air box. Inside of 2" female coupler is actually 2.5" Sam as stock air pipe. But there is a ridge inside the coupler that is 2" inside diameter. I used the dremel to grind this ridge out so there was no reduction in air flow.
The flex pipe is 1.5" PVC smooth flex pipe. It is compatible with schedule 40 fittings.
Reactions: CumminsPusher
Sterno
11
$23 from Napa. Stock rough filter will push right in the end. Adds about 8" height compared to stock inlet and also moves it to a safe spot verses right up front where water can easily splash in....View attachment 45389
Does that hose keep the same inside diameter as stock?
Thanks
what is OD
urbancoyboyja
urbancoyboyja
Buckle Up, I Want To Try Something...
182
389
WV, USA
I went the same route as @Macory. This was a good idea. Ordered the Gates hose from Amazon. They are up to $33 now. Picked up a pack of hose clamps from Advance Auto for $3. It took some effort to get the hose over the nipple but that's ok, it was a good tight fit. Liked about a 1/4" getting the hose pushed down all the way. Put the hose clamp on and stuffed the stock filter in the end. 0d120b390ae9362a0de4ec65aad372f051b614dcc0c98913a14e0c2722832a69
