Difficulty shifting into gear?
Manly bug
21
This is my first SXS so maybe this is normal but it just doesn't seem right. My Pioneer is pretty tough to switch between R, N, D and back most of the time. Then when it goes into gear, it kind of "clangs" into gear. Just does not seem right for a Honda, what am I missing?
I've tried all sorts of different ways of shifting, ensuring there is not stress on the transmission. Level ground, foot on the brake, D, to N, to R, back--it's usually pretty rough.
I was thinking maybe it's because of the climate (I'm in CO) but that does not seem to be the case either, because usually it's around 60 degrees and even after an hour of riding it's still the same thing.
I checked the shifter linkage under the front hood, and everything looks normal, I followed the cable all the way down the side and underneath into the transmission and everything looks normal as far as I can tell.
I'd like to know if anyone is familiar with this--is it normal? Same thing on the Big Reds?
chesterl35
76
Mine was the exact same. It has gotten easier as it breaks in. I have aroumd 300 miles on mine and only
Recently gotten easier. They told me at dealer it would get easier as everything broke in amd loosened up amd they were correct. Nothing to worry about.
I
idahohntr
141
5
Good news! Mine is doing the same thing- it did seem to engage and disengage easily after a few miles. However, when it is cold, kind of a bear
hondabob
1,161
4,537
Prescott Valley, AZ
Make sure the engine is at idle. Shift quickly to avoid the clunk. You can start it in gear also. The Rincon, Big Red, and Pioneer all clunk shifting into gear and its normal. If you shift real slow it will grind the shift dogs. Your dealer should have told you this.
TandT
TandT
357
21
Newark, Ohio
Hondabob is correct. You can not baby it. Just make sure its at idle and hit it hard, I just took my P4 in for it's first service and it is getting easier going into gear. I have 110 miles now. It's my first sxs and it isn't the same as my rubicon 4x4. The more you ride it around the more you are going to love it.
vfr-ray
vfr-ray
Mine too.
Getting better though.
150 miles
Thanks for the shifting tip Hondabob
sek-hunter
sek-hunter
306
572
I found myself parking in gear to avoid the hateful shifts this weekend. You can leave in in 'D' or 'R' when you park. Apply pressure to the foot brake and it will start in gear. That is no help when you need to back up tho! :)
63,409
Best advise is like said above. Do not baby it. Jerk it into gear.
If you slowly pull it, it is possible to be in D when the shift is in N and so forth. Babying it will damage the gear dogs and cause future problems much like the Rincons had if they rub together too much.
It does get easier after some use.
brando4905
42
6
Marion, NC
Mine was like that when new also, now very rarely is it hard to shift.
kgun74
kgun74
15
6
Pottsville Pa
Mine is still pretty new and have the same problem...BUt, I want to plow snow and going from D to R with the groves in dash where shifter locks in place may be a real pain.
What if I took the dremmel and ground off the points on the notches-anyone understand what I mean ? Would it still stay in the gear without jumping out ? Should make it easier for snow plowing, and backing up.
Mudwing
Mudwing
36,959
306,563
The Mud holes
I wouldn’t.
BigBadJB
Vancouver, WA
Same as above. Mine is my 1st SXS and after many Honda Cars and Motorcycles I was really surprised at how difficult it was to shift. I just took mine to dealer for 1st Service at 310 miles and he said shift cable adjust can help but it’s also the way they are. Suprising too that the valves needed adjustment. That’s a 1st for a Honda on 1st Service and such low miles.
CWL23
69
46
Louisiana
Mines a 2019 700 and its a beast to shift sometimes . Had me a little worried. Only have 90 miles on it so guess nothing to worry about seems pretty common.
Reactions: DG Rider
Mudwing
Mudwing
36,959
306,563
The Mud holes
It’ll get better with time. I’m over 1400 miles and it pretty much drops right into gear when I shift. ;)
41,674
It'll get better. They work better if you don't try and finesse it, though. Grip it and rip it!
Reactions: Mudwing
