BRed Dirty Fuel Filter?
K
Kelster
11
Hey Guys,
I've had some intermittent no start issues, sputtering, lack of power, etc. Local Honda shop recommended pulling the fuel filter. So here we are. Not totally clogged but not pristine clean either. Does anyone know how to remove the brass looking strainer?
I've come this far, I may as well put in a new one. Thanks All
20230506 220504 20230506 220511 20230506 220525
Hey Guys,
View attachment 386357 View attachment 386358 View attachment 386359
The sock should pop off, maybe twist off.
The inner filter in the bottom isn't removable without replacing the whole assembly
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,909
19,570
Route 66 Oklahoma
Thank You ! My bad !
I flashed back to my sons 3 Wheeler we called Big Red. That was a common problem with that thing.
Showing my age ! Again, Thank You for straightening that out.
The three wheeler is the first thing I think of too. Had a friend with one, and it is officially named "Big Red".
More atc
K
Kelster
11
Hey There - replaced the fuel pump and my starts are better but I'm getting some rough running at higher rpm and trouble codes. Where can I find the schedule of Trouble Codes? 4 long 1 short.
Is the CEL blinking this code of the gear position?
There is no code 41 for the PGM-FI system
Code 41 for the Drivetrain system is for the Gear Position Switch
