P700 Door rubber stoppers
swsebek
swsebek
2,854
5,829
pa
So lately my doors are getting loose from age.
The only way to get them to not vibrate was to loosen the rubber stopper out sooo far that it would fall off. So this worked pretty good for me now for about 50 miles and 2 months.
I took a piece of red neoprene hose. "I would have used black if I had had some" I cut it 1/4" and ran a screw through it and the rubber stopper. I can screw the original stopper in the whole way now and the screw I used just snug and size wise to go down into the hose so the rubber Just touches. Made them pretty snug with no vibrating. Just thought I would share.
IMG 4745 IMG 4746
DAIII
DAIII
70
92
New Hampshire
Can the doors be adjusted tighter? Mine rattle at day 1 brand new.. and extended all the way out. Thinking the door hinges can adjust some?
swsebek
swsebek
2,854
5,829
pa
Yes.... that rubber is threaded. Just loosen and turn out some. But just as much as you need or they fall out. You will turn them counter clockwise. Take them the whole way out to see how they work then screw them the whole way back in. Then practice loosening them and shutting doors and repeat till they get tight.
But practice cause the latch grabs in two positions.
Also check your latch bolts cause they often fall out or come loose on these 700s
Backwoods
Backwoods
32,594
334,228
Douglasville ga
My passenger side rattles a little I backed my stopper out and still does it some . I may try that hose trick.
207,989
Rinconruss
Rinconruss
40
64
Lakeland Florida
Cheap fix. Go to your local big box stores and buy a set of the self adhesive rubber feet you put on the bottom of chair legs. Stick them to the door where the adjustable rubber stoppers touch it. I had to use two of them but the doors no longer rattle.
swsebek
swsebek
2,854
5,829
pa
Hello from the p1000 side of the forum. A lot of guys over there have had luck fixing their door rattles with these. A little pricey, but if my door rattles get bad enough I might fork over the cash.
WR Edition Door Bushing Kit - Honda Pioneer
I seen them, but it's not what's rattling on mine. My latches were jiggling.
That's a good Idea too
Conner
Conner
39
54
I just bent the bracket out the rubber stop is on all fixed .
