P1000m5 Dropped cam sprocket bolt while swapping head
Chamby1000-5
Chamby1000-5
66
129
South Georgia
So I have a 2016 1000-5 deluxe that was having issues overheating believed to be caused by a warped head. So I got a new head and was putting it back together and got everything in and was putting the bolts in the cam sprocket and dropped one into the motor. Should have stuffed a paper towel like I did when I took them out. But regardless it is the motor now, so any recommendations on how to get it out? Anywhere I can put a pocket magnet in to fish it out? Thanks
107,374
You can try that, but either way your Fucd!
Looking at a tear down if the magnet dont work. Good luck!
BTW how many miles and how did u determine the head was warped? Big job for a “believed” and not a 100%
Reactions: JenElio
DRZRon1
DRZRon1
867
2,816
ahhh, no worries - s*** happens -
magnet, long forceps, shop vac with a piece of small diameter vinyl hose, - basic fishing
Worse cones to worse, just take oil pan off
906UP
906UP
13,125
122,576
da Yoop
I'm thinking one of those magnets on the flexible coil type handle, just take your time, you'll get it
Chamby1000-5
Chamby1000-5
66
129
South Georgia
Well I’ve done everything to try not to overheat but finally found out that it was pressurizing the coolant system, not surprising since it spent its whole life at the mud park and I’d ride it hours after the light was flashing at me. Really shocked it made it this long, but got a great deal on a used head from a 1000 that had electrical issues, so almost had it swapped and dropped the dang bolt
Chamby1000-5
Chamby1000-5
66
129
South Georgia
How might one take the oil pan off? Didn’t know they had one. Thought if I could fish it out someday I would have to split the case
Chamby1000-5
Chamby1000-5
66
129
South Georgia
Got it turns out just needed to sleep on it.
9baa8652aa29fa3c9c327b9023a4a7c5
StewB
StewB
677
3,129
Glad this worked. I dropped a roll of vinyl tape in the air intake and beat myself up for not covering the intake whilst working above it. The fine folks on this site helped me fix it without a big tear down. (It involved a leaf blower, string and a rag.)
Russ989
Russ989
22,593
146,770
Easy, turn it upside down and shake it. 😉
