Dual Battery Gauge Install
ScottJ24
Cresson, TX
I am installing a Dual LED voltage meter in my 2021 Talon R. Is there a ground available that only connects when the key is on? Wiring it as per the instructions the LED gauge is always on. Works real good as a battery drain. Any help would be appreciated.
Reactions: ChadD
5,052
22,653
That's what the relay is for, to switch the ground control off and on, there's no other way to get a switched ground. eta: other than to add a separate/manual toggle switch.
The orange thing, top center, is the relay -
1707014478630
ScottJ24
Cresson, TX
That make sense. It would have been nice if the instructions had included that info. Thanks
Reactions: ChadD and CID
Scoop
Scoop
4,241
15,891
  3. Talon R LV
IIRC, the kit I bought from the Hondasxs.com club store a couple years ago included those instructions.
ScottJ24
Cresson, TX
Well I got the acc hot ground relay in today and it is working as it should. Thanks for all the replys.
