Resource icon
Dual Battery Install with TRUE Isolator
Manwell
Manwell
803
2,439
I really like the idea of going under the drivers seat for a second battery location. That really opens some room under the hood to make a neat install of the Bussmann fuse / relay panel I've purchased... (I've been pondering how I wanted to mount that) Now I'm thinking and that is never safe for my wallet! The isolator could stay under the hood and just run the cables, it's really not that far on this compact machine. I've already purchased and installed the Odyssey PC925L and have it installed in the traditional location. Don't think I need more battery than that at this time, but under the seat sure allows for larger if need be.
321,218
Under seat is a great option for many and you can go with any battery. For some that's used for storage and myself that's a goldmine for a bass speaker lol
Reactions: sharp and Eltobgi
321,218
That's what I needed to know!!!
Well there are many ways but we'll use our rig for campsite fun,lighting for getting wood or fixing something while vehicle is off so for our application this is the best route but this wasn't our first rig so I've already weeded out most of the mistakes. Just on the Pioneer platform alone I've done 3 huge builds in just over a year and we're a high usage type but for many this setup may be overkill but it does not fail which is important. The only problem still becomes alternator laying down only so much power.
Reactions: sharp and JTW
Manwell
Manwell
803
2,439
I never considered under the seat for the second battery, thinking way too much "in the box"... Under consideration for sure at this point.
Reactions: CumminsPusher
321,218
If done right you could still make room for some goodies
Reactions: sharp and Manwell
Manwell
Manwell
803
2,439
I totally agree with that... I would probably build a box for the battery to be housed in and secure that with a cover. That would still leave room to pack other stuff in there. I was thinking about a waterproof container and some basic first aid supplies.
Manwell
Manwell
803
2,439
Ordered the cable and related connectors to move the battery under the drivers seat and hope to have it done at some point next week. I've been going back and forth with a few different locations for the Bussmann fuse / relay panel and now a great spot with easy access will be available. SWEET!!
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Versus doing the dual battery setup?? Or using the deep cycle as the second battery?
Mine is a dual battery with the blue seas add a battery kit works great for me and has never let me down! Here is a picture of my Yellowtop under the drivers seat...
IMG 3892
Manwell
Manwell
803
2,439
I've got a dual battery and isolator under the hood already, going to leave the isolator under there but move the battery. I've got an Odyssey PC925L that brand new and I will just move it. Not 100% sure on securing it at this point, but have a few ideas.
I'm thinking of adding something like this under the seat.. and then putting a battery box in it storage/battery
IMG 0884
Reactions: Tigermark
321,218
That's a stout storage container jtw! Do you have a link to it I'd like to check it out.
Reactions: JTW and Tigermark
Manwell
Manwell
803
2,439
Nice storage box!
I was thinking of way more primitive for a container or not doing a container at all and just strap it down good and cover the terminals. It's a dry cell battery so I don't have to be concerned with acid spillage.
Reactions: JTW
Manwell
Manwell
803
2,439
Got started tonight with the battery relocation and got the cables pulled and strapped down. I was surprised that it took almost 10' of cable, didn't expect it to be that much. The battery is going to work well under the seat and I think I can strap it down with some of the huge cable ties combined with some dense foam and perhaps two sided tape as well. Hope to finish it off tomorrow night. Now I have a prefect spot for the Bussmann fuse / relay panel!
truc577
truc577
130
360
NEMO
So instead of running the aux ground to frame can't you run it over the ground on the main battery?
truc577
truc577
130
360
NEMO
Ok that means that may not be the best practice. I just hate breaking loose factory grounds and also drilling in new grounds. These things are all plastic. LOL
Reactions: Tramguage1
Tramguage1
Tramguage1
Texan
7,198
27,841
Somereset, Texas
I ran a cable for the ground. I dont like using the frame as a conductor to carry current.
Reactions: JTW and ohanacreek
truc577
truc577
130
360
NEMO
So I noticed, as JTW said some are running aux ground to main ground. Did anyone ever call the designer and find out if this is what keeps the blue light on all the time? Hooked mine up and the light has stayed on for an hour. That in mind I took the battery out of the box and hooked it up without trickle charging it first.
