Dual Battery setup
Tims1000sxs
Mississippi
how to put in bypass switch in to use second battery with the key not on just dont understand what the switch goes to
Reactions: TxDoc
5,038
22,537
The switch goes to the same place your 'key on' power goes. IOW - if the 'key on' is triggering a relay/stinger that turns on your fuse block, that's where you connect the switch.
Reactions: TxDoc
Hillbillytnt
Hillbillytnt
518
1,902
Ky
The switch goes to the relay controlling the second fuse box. That’s how mine works tge club store sells tge switch and has a great diagram of how to wire it.
Reactions: CID
