P1000 Dual battery
CJQuig
CJQuig
69
199
St Johns, Nl, Canada
Im about to begin install the dual battery with dual volt meter. Im almost set jus need some clarification that I couldn't find in other posts.
What needs to go between fuse box and 2nd battery? positive bus bar?
Where do I connect the key on power?
If the fuse box is wires to aux battery will all accessories be on all the time?
Thanks in advance
CQ
63,705
A Stinger or other large relay control method.
What year machine?
2016-2021 you need this... or you have to tap a key-on wire
2022+ you can use the new ACC port.
Yes, that's the job of the stinger.
But if you want to control it you can get our new Relay control harness. Or, run it key-on only.
Thanks in advance
CQ
106,101
CJQuig
CJQuig
69
199
Thank you, just ordered from the store
IMG 3753
