![The Green Goat](/data/avatars/m/26/26326.jpg?1686275643)
The Green Goat
I think? Hard to remember as it's been a year. It was quite a bit.Fronts and rears?
No. If you want to, PM your PH # and I will walk you through the procedure in 2 minutes.Fronts and rears?
I took measurements of ground clearance with the stockers and then set the WE's so I had the same.
Yeah, I think I'm gonna reinstall the stockers and do the same...
And after a ride they tend to sag and settle. Will probably require more adjustment until they and you find their happy place.Looks like I need to raise the front 1/2", and lower the rear 3/8" (give or take a sixteenth or two). As measured to the bottom of the frame member at each closest point ... using the Elkas as shipped to me.
Good question.I'm new to the sxs world but have always had a utility ATV. Just picked up a used p5 last week and I'm thinking about new shocks. I rode the big kawasaki mule pro the other day and loved how smooth it was at slow speeds. Does anyone know how stage 1s would compare to something like that?
Doubt they would help much at low speeds as there isn't much spring real estate for variable rates. The Walker Evans, which are similar to the Elkas are known for needing to be pushed hard to feel the difference. They're still rough at low speeds, IMO.I'm new to the sxs world but have always had a utility ATV. Just picked up a used p5 last week and I'm thinking about new shocks. I rode the big kawasaki mule pro the other day and loved how smooth it was at slow speeds. Does anyone know how stage 1s would compare to something like that?
So I likely wouldn't see much difference at 5 to 15 mph?Doubt they would help much at low speeds as there isn't much spring real estate for variable rates. The Walker Evans, which are similar to the Elkas are known for needing to be pushed hard to feel the difference. They're still rough at low speeds, IMO.
They will be a big improvement over stock shocks, but they are a set it and forget it as far as adjustments go except for preload. They have to decide were the sweet spot is for most riders. the stage one have most of the improvement at higher speeds and bottoming out. Still big improvement over stockI'm new to the sxs world but have always had a utility ATV. Just picked up a used p5 last week and I'm thinking about new shocks. I rode the big kawasaki mule pro the other day and loved how smooth it was at slow speeds. Does anyone know how stage 1s would compare to something like that?
Depends on what your expectations are. The sxs will be more composed all round but I would not say they will be plush at low speeds with sharp edge type bumps. Much better than stock. I would say they might feel stiff to you but not harsh if that makes sense.So I likely wouldn't see much difference at 5 to 15 mph?
Smooth is not really a word that will likely be oft used in the same sentence with P5, even with aftermarket shocks. Very much improved, absolutely yes.I'm new to the sxs world but have always had a utility ATV. Just picked up a used p5 last week and I'm thinking about new shocks. I rode the big kawasaki mule pro the other day and loved how smooth it was at slow speeds. Does anyone know how stage 1s would compare to something like that?
Agree, x3.
Welcome, from Kentucky. Congrats on your purchase. Post a pic of it if you get the chance!
Nice way to put it
That's because its designed to be taken off jumps.My p5 was much stiffer than anything else it looked at.
I understand that.That's because its designed to be taken off jumps.
