Extreme Metal Products - EMP Rear Bumper
sksshooter
79
got my front bumper mounted up today. when I received it last week the box had 2 passenger side brackets and no driver side bracket so had to wait on it to come in. this thing is massive.
5D919189 241E 49F5 BE6C 901B97C1C04C zpsyd07blf2
8A6577DF 7B5A 45B6 A555 0BE1272FBEC1 zpsbew5zion
5D030D14 8BCD 44F2 B50E 9A305CA4AD46 zpssonft7fy
pipefighter577
pipefighter577
120
Ohio
Looks awesome!!! Sticks out a bit much on the sides I think but I guess that's more protection. Does it come with any extra support brackets? I was concerned about bending if you hit something or push a tree with the corner.
I like it!
Sadly it will be a while before I add any coolness to the P4 we are breaking ground on our "forever" house shortly so our spending has been focused on that.
I even took the windshield and cab off order, won't need them till next Jan anyway.
SKS, do you have a KFI winch mount? Looking at the EMP page it looks eerily similar to the EMP winch mount.
sksshooter
79
I don't have a winch bracket at all actually. I don't have a winch and am still undecided weather I will get one or not. if I do though it will be mounted on top of the bumper.
63,409
Found some time to modify my brackets today. Should have time to get it installed tomorrow.
63,409
Well, I finally found time to install the rear bumper this past weekend. Taking the side fenders off turned out to be a pain. Mostly because of Honda's GOOD use of lock tight on a phillips head screw.
Here is the modified bracket with good clearance.
And the rear bumper.
sksshooter
79
I recomend anyone planing to do this task or any other for that matter to have one of these or similar on hand before starting. It literally took me no more than 10 min to have both doors and sides off and then the same to reassemble. With a proper fitting bit those Phillips head bolts came out without issue. Same with the doors.
http://m.homedepot.com/p/Ryobi-18-Volt- ... 100049838/
