P1000 Few more questions and updates on my build
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Hello again everybody hope your well I want to say I really appreciate everyone’s help with my build so far big things are in the works weather you agree with them or not is ok but I wanna share with everyone
so recently I dropped some extra money into new upgrades I have new tires 33x9.5x20 also came with new rims I have 6 in portals with 45% gear reduction and a powervision 3 tuner all showed up today I have already installed front and rear a arms so very excited to see the turn out
still a lil upset that super atv has not released a aftermarket axle for my buggy I called up there and the girl told me there are no plans to make one so maybe they can shed some light on this if they see this post
biggest issue right now is I went on one of my longest rides the other day after installing the a arms (other mods not on yet) and I over heated all the way till the light came on I have read threw some post and found that cleaning radiator may help along with a custom tune so I will work on that but can someone shed some light on the fan switch override and the lifted burping I’m not familiar with these
last thing if anyone has any new info on the axles for my limited I’m listening Honda is saying back order with no eta but my front left somehow has a slight warp in the shaft any ideas on what I should do about this anyone have a video on how to assemble or rebuild these axles
I know it may not sound like but I have done a lot of research just haven’t had any luck
thanks In advance once the new parts are on I will post pics
Reactions: JenElio
ToddACimer
ToddACimer
Pioneer 1005-2
3,566
14,638
Oshkosh, Wi
What do you mean by a warp in the shaft? Do you have a picture? What are you running for shocks? Do you have any kind of lift kit installed with the a-arms? Which a-arms?
Reactions: JenElio
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
When it spins it hops slightly, no but I can take one tomorrow morning , fox shocks, no lift kit, super at. A arms front and rear with the heavy duty ball joints
JenElio
JenElio
65,238
610,351
Loxahatchee, florida
🤔....I don't think the a-arms would cause the overheating. Maybe just a dirty radiator or an air pocket in the system.
Lifting the front of the buggy up and running it most times "burps" the air out. There's also a pressure release bolt on the lines.
The fan override you can buy from the club store, it lets you control when the fan comes on......always on, off, or auto I believe.
Also, I would think @SuperATV would be working on the "LE" axles soon seeing as there's quite a lot more Hondas out now running them.
ToddACimer
ToddACimer
Pioneer 1005-2
3,566
14,638
Oshkosh, Wi
Does the CV joint with the hop click at all while rolling or turning? You may have over extended it and bound one of the balls in the joint. You may be able to remove the shaft, remove the boot, clean the joint and debur the spot where it was bound.
Reactions: TripleB
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
I have not have not heard any clicking or popping noises I also installed the stops that came with the a arms
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
I hope so I will try to clean radiator and burp the system
Reactions: TripleB and JenElio
JenElio
JenElio
65,238
610,351
Check to make sure the fan is turning on. The one and only 🤞 time mine overheated was fue to a small amount of mud I missed while cleaning the fan. It dried up stoping the fan from spinning, luckily it didn't damage the fan but when radiator boiled over it created a air pocket that lasted the entire weekend I rode until I was able to burp it. Good luck 👍
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Do you have to take cap off when you burp it at an angle
Reactions: JenElio
JenElio
JenElio
65,238
610,351
Way I did it, left it on till it started to cycle through then very carefully and quickly removed cap. Nothing happened.......but then it did 😂. If yours didn't boil over then you didn't loose coolant. I had to do a coolant change cause I added water mid trail. As I kept adding coolant it would burp now and then. I let it run for a while full of coolant until it burped no more. Been almost 2 years no issues 🤞
Reactions: TripleB and CID
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
What coolant you use
JenElio
JenElio
65,238
610,351
There's also a pressure release under the bench seat somewhere. You may want to try that first see if you can get to it that way. I've not done that since I had to add coolant to mine anyways so I just burped it. Last I read @Bastardchild done it to his machine a while back.
P1K5Dave
P1K5Dave
2,181
8,165
Petoskey, MI
I'm pretty sure @SuperATV reported in one of your other threads that he was hopeful they'd have LE style axles in October...
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
You are correct so I called up there to verify and they told me there are no plans to make any
Reactions: SuperATV
SuperATV
SuperATV
1,249
8,727
Madison, IN
www.superatv.com
This is true! The plan is to have them ready by the end of October. Fingers crossed.
Sorry @Bigmanlittlebuggy . Some of the guys back on the phones aren't really privy to that kind of super secret "insider" info. ;) 🤣
Sometimes I feel like the Wizard of Oz with inside info....and sometimes I'm just as blind-sided as everyone else.
Wizrd of oz pay no attention
