FI Injector Wiring Kit.
63,686
The Pioneer 1000 is becoming known for having a faulty FI connector connection. If you contact Honda in regards their solution is to replace the entire wire harness which will take several weeks to complete.
We have an easy fix that will take no more than an hour with a "soda" break.
Honda Pioneer fuel injector wire repair kit!
Below are the instructions for repair.
Locate the broken wire. Sometimes it will be like shown, others it will pull out with little pressure.
D7ec623c36932b977a499c2abf4f50fc3e77f79fa7feba19e8a4e7853548364f
Remove the seat back and the cover for best access. You could do it from the rear but its difficult. Another option is to remove the air box.
71ffb60da7032ab86d7f29f93b769a44
Cut the defective connector off and strip back the wire tubing.
I cut off 2 inches on the OEM wires.
Strip the wires ends about 1/4 of an inch.
8440a51ce3a29472fcb2303c689ac70965997ea256bba22ced7eff3e8dad0ebb8f3b24f4c95c5cbd20a80404cc1771ee
63,686
Install the large shrink tube over the OEM wires like shown.
E0f0c8bc73462ecd1ee244d9aa099098
NOTE:
We include butt connectors. BUT we highly recommend soldering the wire if you are able. This provides the best and most solid connection. The included shrink tube will work great to protect the soldered connection
Now its time to crimp the wires. Its important you get a solid connection. We included 1 extra crimp in case your pull test fails.
GETTING THE RIGHT CRIMP.
Its important to get a good crimp. We recommend having 2 crimps on each connector. Crimp each off to the side so you leave room for a second crimp. If your first crimp is in the middle it may not work correctly as it will slip into the same location.
If not already, push back the loom to make room to work like shown. We cut our wires down to 4 inches and left the loom full length. Strip backs the wires on the repair kit 1/4 of an inch.
Ef016dbda0f6e3f40e58e03e45a9bb76 jpg 621fc6283f3800426a0c5f3bd2aab70c jpg 254df4d908058c5afd5a964fdfbe0b9f
Next, Twist the wires ends and insert into the butt connectors. it should only go 1/2 way on one side.
8f2f7acb25dbf673431d5f8106af2af4 jpg
Now, apply a great crimp. Do one at a time and perform a pull test to ensure properly crimped.
1b0c0be382624180a812f5e4b224b5aa 5a2786c31a9c8b0dd8d234fc3ce4ddcc
Install the smaller shrink tube as shown.
4197f0d9246f5650ad0f0fd31a3b36ae
Now the final main step.
Crimping the repair kit to the OEM harness. Again, do 1 at a time and ensure to do a pull test on each.
Insert the OEM wires into the butt connector. Crimp good and tight, recommend 2 crimps close to the end. Be very careful not to slip and cut the wires.
B3dcaa189098e487169acc31a07af6e4
Push the shrink tube over the butt connectors. Use a heat gun to shrink, A lighter or torch will work but be careful not to burn the wires. The tube has glue that will seal the connections.
C75bf62f49eb5c0d388ae338c12675b4
Finally, push the wire loom down and over the OEM wire casing. Now use the larger shrink tube and complete the job.
94e3e0a174b55d502bb30b0055b8751c
Zip tie the repaired wires to the other wires to prevent rubbing.
28a8c10c7b9faaddba63c37b79a73a07
Install the connector and test start the unit.
If you have any questions or run into a problem please let us know.
We guarantee our repair kits to hold up for the life of your machine!
Bobjones
16
North
I think I have that issue. Just confused that the wire on one cylinder would kill the engine like the key is turned off. I'm guessing the computer works in funny ways. Would the computer be messing with my mind. Whats your opinion?
Regards, Bobjones
63,686
Regards, Bobjones
Idk
But it can and for some it doesn't.
Let it idle and move the wires around to see if pattern changes.
HondaTech
Regards, Bobjones
One of the injectors will let it idle on 1 cylinder for a but till it throws a code. The other cylinder shuts it off immediately.
Seems to be involved with the way the MAP sensor times the injector pulses.
Bobjones
16
North
Well I changed both injector plugs but I'm not sure. I cut them right at the plug and all the wires looked good.
I was thinking I would've seen thin stretch out wires but no. The ones from hondaSXS are heavier gauge then the OEM. Well time will tell???
SXSPLUG
208,013
You have done well Pilgram.
Reactions: CID
