P1000 First Honda Pioneer!
ArkansasDeerHunter
ArkansasDeerHunter
5
45
Arkansas
CECB86C5 0CCD 4F07 BFB5 4984033FB99F
Just got this 2022 Trail Edition 1000-5. Got the backup lights mounted and my Exogear soundbar. Got all the stuff for the dual batter install, some cube lights, 3d printed rocker panel from Crossroads3d. There will be more pics to follow.
I do have a question regarding the backup lights. I have the splitter and the switch so I can turn it on and off when needed. Probably a stupid question, but what’s the order of hooked? Does the splitter plug in the factory connection under the rear and then the switch from the front plug into the splitter? I hate being a newb!!
Thanks in advance and I love this place!
NTCPrezJB
NTCPrezJB
President of #NTC
100,381
897,212
Canton, OH
View attachment 372061 Just got this 2022 Trail Edition 1000-5. Got the backup lights mounted and my Exogear soundbar. Got all the stuff for the dual batter install, some cube lights, 3d printed rocker panel from Crossroads3d. There will be more pics to follow.
@Hondasxs store wiring question above
63,543
Welcome.
If you are talking about the work light trigger kit. It plugs into the backup harness with the switch up front.
If you are running the backup alarm port splitter, then it goes like this.
Factory backup port --> splitter (a) & (b)
(a) ---> work light trigger kit ---> Backup lights
(b) --> whatever else you have decided to install.
The work light kit has a switch, this will run up front. But it easier to start the installation from the front and follow the main wire harness. Use a stick to get it under the skid plate from the passenger wheel well, then pick it up under the seat at the gas tank.
Well, hope I understood your question and the above make since.
Thanks.
OlYeller15
OlYeller15
192
1,170
Welcome from NE Ga…Let the good times roll!
ArkansasDeerHunter
ArkansasDeerHunter
5
45
Arkansas
Welcome.
Thanks.
That helps a lot! Thank you. I like to learn to hard way. Appreciate it!
JenElio
JenElio
64,260
602,880
Loxahatchee, florida
Welcome! What’s that cylindrical part just below the roof?
Think it's his sound bar. Don't know if it comes with that light strip or not though.
By the way, just a FYI. When you want someone to see your question (quicker) you can reply to their message or tag them by using the (@) and their name. 👍 they'll usually get a notification that way.
5,024
22,434
I'd just add that 'Reply' is in the lower right corner of every post. @RedorDead 😎
ArkansasDeerHunter
ArkansasDeerHunter
5
45
Arkansas
@RedorDead it is my soundbar. It’s an Exogear and the light strip came on it. It sounds good and so far very happy with it.
Similar threads
