P1000m5 FOX shocks spanner wrench size
Seadonist
Seadonist
380
1,117
New Orleans
Anyone know what size spanner wrench/ wrenches I need to adjust preload for n front and rear? Thanks
Rayger143
Rayger143
2,753
23,850
Winfield, BC Canada
I've borrowed spanner wrenches. Don't know what size they are. I hated using them. I found that if you jack your buggy up and loosen the lock nut I can adjust by putting on a pair of gloves and turning the spring. Anti seize on the threads helps.
Reactions: Robobrainiac
john790
330
1,016
Clinton ohio 44216
I have a nice spanner wrench i cut the handle down worked good on the rears but no luck on the fronts i had to turn the springs.Just no room on the fronts.
Reactions: Rayger143
208,014
Spanner set
they take a 2.5 front and 3.0 rear. I bought both and this spanner set, which worked well.
And one of these
it also worked.
The Fox wrenches had the best repetitive fit, but stupid expensive.
I just clean up the threads, lubricate jack it up a little break the locking mechanism lose and spin the spring.
Dirtstiffs-1000
Dirtstiffs-1000
1,563
5,698
hondasxs.com
Good deal.
I did same on front and removal of oem rear spring.
My new 350# rear springs are too tough to hand tighten preload.
