P1000 Front axle replacement
hurld
hurld
129
159
yes, driver side front
Curious how you broke it. Limited Edition models don't have Diff Lock which causes most front axle /CV joint breakage....... I'm no help to you as far as replacement, but I can tell you the LE models use a different axle than the other models.
Sent from my SM-N960U using Tapatalk
Kilo427
Kilo427
1,543
6,439
But they can’t be broken on a LE? Take it back to dealer surely it hey will warrantee it. I don’t know they make spares for a LE
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
Looking for instructions on how to replace the front left axle on a 2017 Honda Pioneer 1000-3 LE.
It is just some nuts and bolts. No specialty tools with the exception of a 30mm socket for the axle nut. No different than your car.
Remove wheel,
Remove axle nut
Pop ball joint free from spindle
Push axle thru spindle
Pull axle from diff
Reverse to install.
slucas81
7
Kentucky
Broke while riding rough rocks in very cold temp. Ordered replacement from dealer. Not sure what our next move will be.
slucas81
7
Kentucky
most likely going to have to take it back to the dealer!
Reactions: sharp
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
I just checked the service manual, it only shows how to rebuild the axle, not how to remove it from the machine.
Reactions: sharp
slucas81
7
Kentucky
Does it have a part number? the one we ordered through the dealership won't fit.
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
I'll screenshot a shopping list. You can confirm the part numbers with your dealer.
Neohio
Neohio
Beast of the East
13,420
65,821
Painesville Ohio
Screenshot 20190214 181458
Reactions: JTW
