Multi Front bucket for plow mount
Mudder
Mudder
NTC Ambassador of Walls
11,355
84,519
2228C5F1 61B4 4219 AF86 D4D10CDA4512
0AB818DF 4CEB 4878 9DFA 7CFF3E6C2B46
FYI, found some pics done years ago for atv plow. Latest version uses 2 swinging legs (rearward of clip pin) to support raised bucket off ground, then spool out cable to dump. Uses pulley point on plow frame near bucket, then cable goes upward to attach at top of bucket for dump feature. Up, down and dump with just winch. Disregard verticle red verticle angle iron at winch/bumper..just an earlier hold up idea not used after adding legs (legs were added after picture was made). Was a good garage project for fun.
Reactions: BWAF and Mudwing
U
uconn411
160
255
CT
Nice work. I don’t have the fabrication skills so I just bought the Warn 60” plow and added the bucket kit to it. Works well for general use. Has a trip rope you pull to dump the bucket.
52f16e39ae383e9d47bd74eb698a9647
0cf6b2ad192c6884b0aa1f6af5c7ffea
Mudder
Mudder
11,355
84,519
Stumbled across the simplified drawing I used for follow up modification of plow mount (above post) to create a lift/dump bucket function with a single line winch. Swinging legs with small foot support the bucket for dump on spool out when stopped. Spool in to raise bucket while driving forward to fill.
D9A3D521 4D2B 4C41 B500 D17E31F7C165
