P500 GMRS/HAM antenna mounts
K
Kilroy
92
284
I am going to install a GMRS mobile and maybe a 2m/70CM dual band radio in my P500. I am curious where everyone mounts their antennas at.I have a roof and back shield on mine along with an aluminum toolbox mounted directly behind the cab on the rack.
108,193
Lots of info like crazy up top in the 🔍 heres one of many. You have to scroll through the pages to see where some have mounted them.
Scoop
Scoop
4,280
16,045
  3. Talon R LV
On my P1K5, I run a Tram 1181 Dual Band NMO Mount Antenna (140-170/430-470 MHz) using an Axia Alloys Adjustable Angle 2 way Radio antenna mount (1.75" clamp for my ROPS). It's mounted on vertical ROPS back by the tailgate on the driver's side. I've oriented it so that the antenna is about 85% below the roofline and completely inside the ROPS (so nothing hits it on the left, especially if I end up leaned up against a rock wall).
You might be able to do something like that on the P500 ROPS - just make sure you get the correct sized clamp.
1700604037651
Reactions: Remington
Scrappapotamus
The Scrappapotamus
422
2,092
Midway KY
  3. Talon R
  4. Talon R LV
The mount on your rops offset from the LED light doesn't interfere with how your radio works? Those lights throw off all sorts of noise and usually scramble radios
The light next to. your antenna doesn't cause issues with your radio?
K
Kilroy
92
284
I don't know if I have room for a ROPS mount with the back and roof on my P500. I read through that thread on P1000 installations already. I was curious what P500 owners were doing.
Scrappapotamus
The Scrappapotamus
422
2,092
Midway KY
  3. Talon R
  4. Talon R LV
I would keep any antenna away from a LED light. Led lights emit some sort of noise that plays havoc with most radios that receive of transmit signals like radios were years ago if you didn't install a noise suppressor.
Reactions: futzin
Scoop
Scoop
4,280
16,045
  3. Talon R LV
Negative. All worked perfectly fine @ TO23.
K
Kilroy
92
284
I decided that I will go with a Comet CA2x4SRNMO antenna with a magnet mount. I will place the antenna on the metal rack for everyday use so that I can get in and out of the garage easily. I can always move it onto the tool box if I need it higher. The rack and tool box will work fine as a ground plane.
K
Kilroy
92
284
I got my Wouxun KG-XS20G GMRS radio mounted in the 500 last night. The radio is 25 watts and I am going to try running it from the accessory plug on the dash for now. I tested it with a short antenna and it worked okay. I will be ordering the 40" Comet CA2x4 antenna for it soon.
GMRS radio
11,383
84,901
My radio mount using a ROPS clamp, and the antenna on the right front fender.
IMG 6904IMG 0347IMG 0353
Reactions: futzin and Scoop
K
Kilroy
92
284
I decided to put my radio on the dash since my current windshield does not go all the way to the roof and water comes in when I get caught in the rain. The rain is IP67 rated by I don't want to push my luck. I decided to use the metal rack in back for a good ground plane for my antenna. Even no ground plane antennas benefit from having a ground plane.
Reactions: Scoop and Mudder
Scoop
Scoop
4,280
16,045
  3. Talon R LV
Our rain is IP69 rated. Your rain must be sissy rain. :)
Seriously ... IP67 will stop complete dust ingress and withstand being submerged in 1M of water for up to half an hour, so rain coming up under the roof shouldn't matter.
My AnyTone AT-778UV hangs off the ROPS in the upper left corner using RAM Mount bits.
1701132778733
1701132868783
Also use one of those Hammerhead Industries retractable microphone holders so the mic is always where it should be unless I'm using it. I connect it to the middle ROPS crossmember (behind my seat) and it keeps the mic cord above my head.
1701133283058
K
Kilroy
92
284
This is very true. But Murphy likes to visit me at times and I like keeping him at bay.
  • Haha
Reactions: Scoop
11,383
84,901
Yep, Murphy makes as many visits as Santa Clause. BTW, I chose the ROPS clamp for ease to use the radio in my truck, found a 9005 headlight plug that fits, so made a power pigtail for the trucks accessory socket.
Reactions: Kilroy and Scoop
K
Kilroy
92
284
I have a Wouxun KG-100G+ GMRS and a TYT TH-7800 2m/70cm radio in my Ford Escape. I am also using another KG1000G and TH-7800 as my base station radios.
If I were swapping radios to different vehicles, then I would have made everything quick disconnect.
K
Kilroy
92
284
Well my Comet CA-2x4RS antenna came in today and I have it mounted on the back rack of my 500. I checked SWR and the highest I got was 1.8 to 1 on the repeater channels and 1.0 on channels 1-7 and 1.5 on channels 15-22. I was getting into the local repeater just fine with the setup at 21.5 miles away.
The Comet CA-2x4SR I a multi band antenna used more for 2m/70cm but also works for GMRS. Now I just need to get a good external speaker for the radio and my setup will be complete.
Reactions: Scoop
Scoop
Scoop
4,280
16,045
  3. Talon R LV
Reactions: Kilroy
