Good off road utility trailer for yard work?
Vikes79
Vikes79
SKOL!
10,998
106,793
South Dakota
  2. Talon X4 LV
As the snow thaws I’m looking at several acres of trees and brush I would like to clear and a good amount of yard I would like to level for my 72” mower.
My pos 10cu Home Depot trailer special isn’t getting the job done fast enough for me and I want something that I can load with smaller backhoe.
I’d like to maybe even modify the trailer for pasture spraying as well (distant goal).
I’d like to keep the expenditure no more than $1k.
I like this design as the cg looks to be lower, but I think tandems would be a benefit.
Nice but appears top heavy, and out of budget
Here’s a better priced one, but I’m worried it may not last long.
I’m curious to what everyone is using? Suggestions?
Vikes79
Vikes79
SKOL!
10,998
106,793
South Dakota
  2. Talon X4 LV
As a side note I have access to a older PTO small unused manure spreader with a good metal floor that I could repurpose by removing the beaters and keeping the drag chain for unloading.
The only issue with this is I would have to use my tractor to pull it around and would / could really tear up things.
I’ve seen this idea used for hauling wood for an outdoor furnace before.
Wallace
Wallace
Well that didn't go as planned
2,812
15,093
Lonoke Arkansas
20180410 170632 001
20180410 170632 001
Reactions: Vikes79 and Mudwing
O
oldfortyfive
596
1,321
Illinois
How durable is it?
Would you be afraid to fill it with a bunch of rock or pavers?
I've moved a lot of scrap concrete chunks with it (I put a piece plywood on the bottom just to be safe). You can pretty much load it up flush with gravel, but do take it easy moving around full. I bought it due to it's light weight, making for easy storage.
K
KFCK
6
usa
I got a Bannon from northerntool.com that I use with my 1000-5. has a hitch - 1600lb capacity - 3pt rear wheels pivot - flared side panels and all 4 panels removable - use it on the farm side and through the trails and It takes a beating!
C2FC4FC8 FB91 4C7F A26E 0A743D706E3F
Reactions: Vikes79
P
PDBuilder
You cant go wrong with the polar unit ,same company makes a lot of ice fishing sleds (Clam Corp ) out of Minnesota no I'm not getting compensation for this endorsement just have one of there single axle units here on the farm ,and it is heavy and well built
Reactions: Vikes79 and Cal
Vikes79
Vikes79
SKOL!
10,998
106,793
South Dakota
  2. Talon X4 LV
Thanks for all the ideas!
It’s nice to see constructive feedback on some of the trailers out there for purchase.
Vikes79
Vikes79
SKOL!
10,998
106,793
South Dakota
  2. Talon X4 LV
I find it weird that it has 8 tires. I’m having real hard time getting past that.
About how far is the bottom of the bed from the ground?
Some of these trailers bed bottoms are either at your ankles or what appears to be 4’ high.
K
KFCK
6
usa
K
KFCK
6
usa
It’s got 12 inch clearance- hauled rock - stumps and once a tree over 10 ft long over 2000 lbs - only down side is I blew a tire once clearing trails with a heavy load - second tire held up great but Northern Toll is the only replacement supplier. Not only have beaten the crap out of it the tires have been kind to my lawns
You should have bought one of those golf cart beds and just stuck a little trailer under it. @Kilo427 might sell you one.
Reactions: Vikes79
I’ve got one about like this... why not just go this kind of route where you can actually do something with it?
1B30788B 9D3B 48B8 9AA7 02F5B25BE8E1
Vikes79
Vikes79
SKOL!
10,998
106,793
South Dakota
  2. Talon X4 LV
The soils in my area can be quite soft.
I think a trailer like that would leave a several inch rut in my lawn. My other enclosed and car trailer already do this.
Kinda need something with flotation tires on it.
Reactions: Mudwing and JTW
