Multi Has anyone retorqued their wheel spacers?
41,931
I'm seeing a lot of chatter among facebook engineers on the interwebs about retorquing wheel spacers every x amount of miles. Mostly in the Jeep community. I can see this as a good idea in some situations, but...
Problem is, I installed mine with blue loctite at 85ish percent of wheel torque, so wouldn't turning the lug nut at all "break" the loctite?
I mean...I guess you could go back to that original spec and see if it moves, but if it does, wouldn't you then have to start over with new loctite?
William
William
1,442
2,887
Flowood MS
I never re torqued mine. I blue locktighted them and they never loosened. Hell use red locktight and don’t worry about it... Jb weld them bisnatches....
RB3offroad
RB3offroad
1,703
4,757
Tempe, AZ
We use blue Loctite and we have not had to re-torque them. It never hurts to check your tires and lugs before going out but you should not have to retorque
41,931
Sounds like a NO from the panel.
Usually recheck the wheels a few miles into the next ride if I've had them off.
Reactions: DanDan and rtn001
jamesh
jamesh
253
350
DFW
Divide whatever you read on the internet by two and you'll get closer to reality. I didn't even use locktite on mine. I dont use locktite on my wheel lugs either. I also didn't use a torque wrench. I DID forget to tighten lugs on one wheel for the test ride after install. Just tightened it up when I noticed.
Reactions: DanDan
SWB
SWB
1,972
6,934
South Central Arkansas
My actually thoughts on it is to torque spacers to recommended specs. Loctite if you wish. Install wheels and tires torque to spec. A lot of times impacts will over torque studs causing them to stretch. Which causes other problems. Ride it for little while, remove and inspect spacers. If everything looks good assembly tires and wheels and torque again. Check it every now an then.
NitroxDiver
NitroxDiver
488
918
Concord NC
I used blue on the spacer but nothing on my wheel studs. You are correct if you use lock tight you can not check the torque. You can however inspect them from time to time to be sure the spacer is tight against the axle. Look where the spacer mouths to the axle for any gap, wiggle the tire and wheel assembly to be sure there is no movement and also check the spacers over from time to time for cracks. I feel that checking them for cracks periodically is the most important check.
One more thing to add if you do find one loose you should remove the spacer and clean the surface between the axle and spacer and where the nuts seat. If there is any junk in there it will crush and you will loose the torque on the studs.
Reactions: DanDan
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I used red loctite on my RB3 spacers. They have been on for over 1000 miles without issue. I've rotated tires and the spacers are doing just fine. I agree trying to torque them will break the loctite loose and negate your progress.
Reactions: DanDan and DG Rider
tjoreo
tjoreo
1,011
1,929
Southern Idaho
Don't know if you could use a torque marker so you can visually check to see if they have loosened. Haven't used any myself but have seen a few fasteners that have them on them. Just a thought.
Upload 2019 7 10 8 8 36
Reactions: DanDan
NitroxDiver
NitroxDiver
488
918
Concord NC
Do know if you could use a torque marker so you can visually check to see if they have loosened. Haven't used any myself but have seen a few fasteners that have them on them. Just a thought.
I have used that when I was is school changing oil for a living. It was basically so you could see if anyone had tampered with the drain plug. I would think a good paint marker would work just as well. Just like the little plastic arrows you see on truck lug nuts. If they back off you will have a visual indicator.
Reactions: DanDan
