Multi Heat Shrink Labels! Wish I knew about this sooner!
BobSmithing
Kent, WA
Hi All,
Just ran across a heat shrink tubing you can run through a label maker which prints your label on the HS tubing then you can shrink it onto the wire. Wish I knew about this before. So an FYI for those of you who didn't know. I'm using a Brother label maker attached to my computer to print my wiring labels. Link to the ½" (~17mm) size on Amazon.
2021 03 P 1409 UTV Heat Shrink Label
Prntckt
Prntckt
1,049
7,228
Altoona, WI
  1. Talon X4
Thanks for the tip! I didn’t know that this type of product was available for consumer grade thermal printers. Got some labels on order.
Reactions: BobSmithing
