P700 Heater core leaking
swsebek
swsebek
2,854
5,828
pa
Try to find the Leak and fix it. I had a leak for 2 years I could never find. No fluid just tasted t in the air I searched everywhere and could not locate it. But the level never went down. Most of the time it’s a loose hose clamp.
This is just my opinion “ Do Not Use Stop Leak””” garbage crap that will clog everything later on. Heater cores always fail from stop leak
Dockman
Dockman
168
343
It is wet around my heater core.
  • Sad
Reactions: Buggyman
Dockman
Dockman
168
343
with the constant hot and cold cycles I would check the clamps before you pull it. maybe just need snugged up with a 1/4" ratchet.
Not loose when it's cold but will recheck when it's heated up
Reactions: Farmer and Buggyman
Scoop
Scoop
4,253
15,934
  3. Talon R LV
If the core is leaking, any reputable radiator repair shop should be able to leak test it and solder it up if needed.
Avoid Bar's Leaks or anything similar at all costs. There's no such thing as a "mechanic in a bottle", as it doesn't properly fix the root cause while it DOES risk creating a bigger problem. The ONLY time I'd use it would be as a temporary fix to get you home if you were stranded out in the middle of nowhere and had no alternative.
Farmer
Farmer
2,851
16,389
Southern MO
That's how mine was. No leak just that hint of antifreeze in the air.
