P1000 HELP PLEASE wont go into reverse
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
When trying to put my 2016 1000-5 in reverse the gears just grind. I made the cable adjustment under the battery, didn't seam to change anything . The dash indicator shows the machine is in "R" , no codes or other warnings. If you give it a little gas it slams into reverse , pops in and out of reverse. Every other gear seams to be fine.
1,900 mile on the machine, I have adjusted the tranfer case likage under the drivers seat.
I have searched the forum and have not yet found anyone with the same issue. Any help would be greatly appreciated.
Cliff O'Reilly
Reactions: Lady01 and BWAF
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Cliff O'Reilly
Just because you are adjusting the cable, do you know for a fact it is actually moving anything? Even though this sounds potentially way-out-there, I would be sure to charge the battery and make sure it is in excellent shape, because I know from experience when you battery is low and depending on "electronics" quirky things happen. How is the unit responding going up through the gears?
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Does it shift into reverse with the engine not running?
You may have to rock it a bit while not running to engage. This will determine the next troubleshooting step.
I would say no it does not. Put it in reverse and push forward or backward it goes " click, click,click click.
Reactions: Lady01
riverratcadillac
riverratcadillac
173
626
lafollette tn
your gonna have to tear in to the sub trans mission i bet the edges are worn i had to replace 3 parts in there for it being out of line ill find the pics and post
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Honda
OH NO, sounds expensive.
Strange the problem came on like someone flipped a switch. Yesterday morning there where no problems the first 3 times i used reverse, and all of a sudden it happened on the 4th.
Reactions: Lady01
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
How many hr job is this for the average garage mechanic ? Any special tools needed ?
Why does this happen and what will keep it from happening again ?
VERY disappointed, only 1,900 miles and it has not been beat, rode hard at all.
riverratcadillac
riverratcadillac
173
626
lafollette tn
took me about 2.5 hours but i was doing it on a lift
cjburt22
12
16
Enterprise, MS
Yep. Sorry to say but
Gear dogs and shift fork is going to need to be replaced in the sub transmission.
Hey, I have same issue but not as bad. I have removed the sub trans but I can't see any visible issues. Can you tell me which fork and gear dogs need replaced?
Thanks,
Casey
Sent from my SM-G973U using Tapatalk
Reactions: Lady01
RandyRobinett
Fl
Is this repair covered under warranty
Reactions: Lady01
