P1000 Hi beams not working 2022 Forest
Red B
46
105
Arizona
First off, I realize there is another thread on this topic, but it got derailed on scratches and PDI etc.
So my hi beams aren't working. I have replaced the switch and swapped the relays (both the 4 prong black and the 5 prong blue) that reside under the air cleaner. I actually only swapped the 2 outside sets of relays. Anyway, still no hi beams. Both sides of the beams are out.
Any ideas on what to do next?
Thanks Red
Reactions: TxDoc
107,966
Have you put a meter on it to see if tour getting power from the switch or not and slowly work your way through the electrical system to the light?
Looks like you worked harder there not smarter😉
13,470
66,435
Watch this video on a add a light install.
It shows the location of a 6 pin connector.
Take that apart, check and make sure all the pins are straight and making contact with each other.
Bighat
Bighat
876
3,744
Gallipolis Ohio
Thanks Red
Had this on my 21 model. Got to messing with the fuses and relays and it started working. This was brand new at the time. Must of been something not making a good connection. Worth a try.
Red B
46
105
Arizona
I checked the connector in the you tube video...all looked good. Thanks for the idea.
Red B
46
105
Arizona
No kidding. That's my motto.
  • Haha
Reactions: Remington
NorthernJoe
NorthernJoe
333
1,279
Northern Ontario
Thanks Red
I had bad bulbs in mine from the factory. they had an internal short and kept blowing fuses
DRZRon1
DRZRon1
889
2,896
there are schematics under resources for the pioneer, not sure if the forest model though is the same as a standard pioneer - even so, it should give ya the basic idea of what to follow in the circuit to check
you didn't do anything nuts like swap to some super bulb, etc..?
did they work at some point ? have you by chance tried wiring something in lately?
so low beams are fine, just no hi beams?
Red B
46
105
Arizona
Thanks, didn't know about the schematics in resources. I did not change bulbs. Yes they worked when I got it. I added a RLB to the rear (wasn't hooked up the the front lights, but I used RLB's harness to display tail lights on the bar). Low beams work fine. Haven't used the highs much because I have a 12" light bar on the front (wired on a different switch).
If I was to replace the OEM headlights with LED head lights, what's the best drop in replacement?
Thank to everybody for the help.
107,966
Ebay, thats where i got mine some yrs ago. The oem price at the steelership is a Rape!
Soooo have u used a meeter to trace power starting at the switch back to the high beams to see where your power is braking and BINGO! Theres your problem source?
107,966
Red B
46
105
Arizona
I haven't traced it yet with the meter. I installed a spare tire carrier yesterday then played pickle ball all afternoon, this RV lifestyle is a busy one, LOL.
Are these the lights you are talking about? For Honda Pioneer 1000 2016-2020 2021 2022 2X 6000K H13 LED Headlights Bulbs Kit | eBay
107,966
107,966
NewHere2
NewHere2
Village Idiot In Training
36,642
310,307
High Plains of SD
Let us know when ya got it fixed. Might help someone else in the future.
Red B
46
105
Arizona
Update...
It was the bulbs. Since I have a 12" LED on the front, I rarely used the high beams. So there's no telling if they went out at the same time or not. But when I noticed them both out, the last thing I considered is the bulbs,
Thanks for all the help.
Red
