P700m4 HID question
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Installed my HID's yesterday (OPT7 brand). Was able to fit all of it inside the housing. however, the cap does not go on now due to the length of the buld. Planing to drill a hole in the cap for the end of the bulb to stick through. Just wanted to see if anyone else had other ideas that worked for them?
Tramguage1
Tramguage1
Texan
7,135
27,112
Somereset, Texas
I used a different brand, didn't have that problem.
Not sure drilling a hole is a good idea. I think if water gets splashed on the hot bulb it will fail. How moch more room do you heed? Maybe heat and a little weight on the plastic cover to stretch it.
Reactions: swsebek
Ems-Cam
Ems-Cam
252
336
Alberta
Do you mean the outer housing or into the reflector?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
sorry, bad wording...
The bulb fits and locks into the reflector, but the wired end does not fit completely inside the housing. The round cap that snaps into place does not fit anymore due to this. The bulb/ element itself is still protected.
Ems-Cam
Ems-Cam
252
336
Alberta
That's what I figured. Where do you have the ballast running?
The outer plug you can cut a
Hole into and use a grommet as needed to plug.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I have everything inside the housing. The ballast and all the wires fit in there.
Ems-Cam
Ems-Cam
252
336
Alberta
Are you able to use heat to extend the larger grommet then?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
not sure, might be able to use a heat gun to dimple it so it will fit. what I dont want to do is warp it so i cant use it at all. Since that cover is not water tight, not sure if a little hole would matter. But i do like the idea of being more water/ dirt resistant
Ems-Cam
Ems-Cam
252
336
Alberta
I think that if you concentrate the heat in the centre and keep the outer diameter unchanged, it will fit fine. Myself with the location of the light in relation to the wheel, I would not want to put a hole in it.
Reactions: Tramguage1
Tramguage1
Tramguage1
Texan
7,135
27,112
Somereset, Texas
How much more room do you need? A blow dryer may produce enough heat to slightly change without changing the outside diameter of the cap.
Reactions: Ems-Cam
Tramguage1
Tramguage1
Texan
7,135
27,112
Somereset, Texas
Maybe a 1 inch socket and some heat you can stretch slightly
Reactions: Ems-Cam
Ems-Cam
Ems-Cam
252
336
Alberta
Can you post a picture or 2 of where/how you mounted it? I have ballasts and have ordered elements so this is on my to do list.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
will try to get a few pictures tonight.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
IMG 63171 IMG 63161 IMG 63131 IMG 63211
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
the distance it sticks out, and how much off center it is. Im thinking notching it will be the best bet. can always silicone around it after
Tramguage1
Tramguage1
Texan
7,135
27,112
Somereset, Texas
Im with Dragon, cut a hole and silicone
