Multi Highest mileage on Your Pioneer ???
sheba4
161
197
mn.
  3. Big Red
Don't Know if this has been gone over I briefly looked could not find anything but just wondering What are some of the mileages racked up on Your Pioneer ? what is the highest mileage We know of ? how many miles before a rebuild ? Mine is a 2017 but I only have about 600 miles on it now,,, Thank You-All :)
I just had to respond, I have a 2018 p1000-5 and have 53 miles on it. 131 on my 2013 Honda foreman and 118 on my 1986 big red...
I just like looking at them... when I go someone is going to have some nice machines...
20190113 155014 20170326 191330 20180211 132436
QuadMan747
QuadMan747
344
566
Connecticut
www.cccmx.com
  2. Other Brand
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
I put A-Arms on front with 14" STI HD9 Beadlocks 5+2 off set with Blackwater EVO's 28x10-14 tires,, and Fox shocks and I removed the sway bar in rear,, It Really did make a difference in ride,,, I could have never figured all that out if it had not been for all the Great People on here helping, Thank You,,,, :)
QuadMan747
QuadMan747
344
566
Connecticut
www.cccmx.com
  2. Other Brand
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
Thanks it looks really good! Wonder if you can run that wheel/tire combo with stock A-Arms?
I think that You could run the 28" Blackwater EVO's they Run a little small anyway , I started out I was not going to put A-Arms on but changed my mind because I thought I may want to go to 30" tires in the future, 28" will be a little close in front but should be Ok if You have a Trail Armor Skid it would probably have to be trimmed a little for the front tires to clear,, ;)
Reactions: CumminsPusher
266,470
Just over 11k miles on my 2018 P1K5LE, just getting front pilot shaft ujoint replaced and front left axle cv joint is worn loose. Lots of hard riding and no failures just hammered the machine loose in the rocky terrain.
20211021 163839
Travis R
Travis R
135
441
Southeast Louisiana
It's at like 18,500 and in the shop now for the first time in a long time getting all new wheel bearings and a-arm bushings. Have a new shift cable for it... (Thanks @hondabob made that diagnosis easy) and a tie rod (encounter with unforeseen stump in Apalachicola forest). All that is to be put on. Runs just like new. I've only had minor issues with it. It definitely has made some believers. There are four pioneer owners where I work, wish I made commission off of selling pioneers.
Ol' gal has been real good to me. I was real concerned in buying the first year model as mine is a 16' but she has never left me stranded. Not once. Still on the original clutch with 31" ag tires now. I use manual exclusively coming from a P500 and don't really mud. I do think that has something to do with the longevity of my machine.
I just purchased a 2016 Pioneer 1000-3 EPS a few days ago with 970 miles. I’ve been concerned about purchasing the first year model of the 1000. Should I be?
Dasmoeturhead
I've got aittle over 3,000 mi on my 2016 Pk3. Mechanically I've done oil changes, and all maintenance. That's it. Ok I did just replace the battery after 6 years. I have no doubt this PK3 will be running fine long after I pass. Best piece of machinery I've ever owned. Never going to get rid of it
It's a freaking Anvil.
T
Texanten
22
Amarillo, Tx
My new to me machine has 709 on it it is a 2017 Pioneer 500..Apparently that is barely broken in. The previous owner added electric power steering, 2500 lb winch,hard top,bright light bar on top and a windshield. Also came with full doors and a rear enclosure that I will probably never use.
